Traction control issue
Old 01-03-2012, 11:27 AM
RPM07LS's Avatar
Default Traction control issue
A couple days ago I was driving, a little fluid spilled on my center console and got around my traction contr button. I immediately tried drying it up as best as I could. I didn't attempt to turn off the tc yesterday but today I'm getting no response from pushing the button. The button pushes but the dash light and dic info doesn't come up. Perhaps Ive blown a fuse? Where is the fuse for the tc located? I've looked around both fuse centers and didn't see it. Or maybe it shorted out, hopefully that's not the case tho. Can someone tell me exactly what fuse I need to check before I do anything else? Thanks in advance!
Old 01-03-2012, 03:15 PM
WhiteGXP313's Avatar
I left the sunroof open in the rain once and everything got soaked. The traction control light kept turning on and off randomly and the airbag light was on. After I vacummed the hell out of the car (interior looks better now haha) and a few days passed everything shut off and is working normal again. Just wait a few days for it to dry up and it should be ok.
Old 01-03-2012, 03:49 PM
Gaspo's Avatar
who needs traction control? remove it!
Old 01-03-2012, 03:58 PM
texasGXP08's Avatar
If the issue persists, the button/switch is most likely damaged. I would replace that first. It is the WORST placement of any button, that I personally have ever seen.
Old 01-03-2012, 08:42 PM
RPM07LS's Avatar
Ok I'll give it some time and even try vacuuming around the button and see what happens.
Yea by far the worse placement ever! Haha
Thanks fellas!
Old 01-04-2012, 12:56 AM
heavyft's Avatar
You could spray some rubbing alcohol around the button and see if it cleans and dissolves the sticky residue or evaporates the moisture.
Old 01-04-2012, 07:49 PM
rm08gxp's Avatar
maybe try some duster and blow that in and around there as well being that it evaporates quickly and doesnt puddle. It could help dry it out?
If it comes down to it, test the switch's contact's with an ohm meter before replacing.
Old 01-04-2012, 07:52 PM
02ws.sik's Avatar
the button should pop off. then you can wipe it off with a wet towel. then get a can-o-air and blow it out.
Old 02-08-2012, 10:34 PM
RPM07LS's Avatar
Little update: I still can't turn my traction control off and I tried to pop the button off but I felt lil I was gonna break it. Anybody ever have this problem that could help. Should I keep pulling on the button until it pops out? Just want to make sure it comes off like that for sure. I don't want to break it! :-/
Old 02-09-2012, 05:49 PM
vroom_vroom's Avatar
mine was like that when i bought the car its not had to pull it out and pop the button off, clean the contacts with some rubbing alcohol and presto good as noe
Old 02-13-2012, 02:45 PM
RPM07LS's Avatar
You say it's not like that? Have to take console apart to do it? Or u mean like it won't break and will pop right off?
Old 02-13-2012, 03:16 PM
the console has to come out(2 bolts on the front and two on the back. the screws inside the console do not need removed. requires a bit of force to pull the back of the console up there are a couple body clips in there if memory serves), the switch has two tabs on the sides,unplug and remove. then you can pull the switch it self apart. not a big deal i used a small flat blade screwdriver to do it. just take your time when lifting the tabs to pull the switch apart
Old 02-13-2012, 06:36 PM
RPM07LS's Avatar
Fantastic! Thank you so very much kind sir.
Quick Reply: Traction control issue
