Exhaust Drone
Old 05-14-2013, 03:58 AM
99corvette's Avatar
Default Exhaust Drone
I installed a set of SLP canister style mufflers on my wife's GXP. They sound great! But have A LOT of drone until you get into OD and the converter locks up. My question is, if I take out the resonator I know it will be a little louder but will it help with the drone or make it worse? What about a catless DP?
Old 05-14-2013, 08:14 AM
JessmoMonteSS's Avatar
Removing the cat and res would just increase drone. I run the 3'' downpipe with no cat and no res into the MF cat-back. I get some drone but it's the nature of the beast. Hard to say what setup would work best for you but maybe different mufflers would help?
Old 05-15-2013, 02:01 AM
99corvette's Avatar
Idk these mufflers are a straight through baffle style muffler just like a magnaflow.I know a chambered muffler like a flowmaster wouldnt have the drone but I cant stand those.
Old 05-15-2013, 03:41 AM
Moderator
91parkave's Avatar
quite the opposite chambered mufflers are the ultimate drone machine
Old 05-15-2013, 03:47 AM
99corvette's Avatar
Nope, I've never had drone with a chambered muffler. Only baffled ones. A lot of it has to do with the way the exhaust system is setup
Old 05-15-2013, 03:58 AM
Brian396's Avatar
Maybe try replacing the resonator with a Dynomax VT?
Old 05-15-2013, 04:05 AM
99corvette's Avatar
Not sure what that is Brian?
Old 05-15-2013, 05:28 AM
Brian396's Avatar
http://www.dynomax.com/mufflers.php?muffler=vt
I wish I could give a review on them, but with me being the motivationaly challenged individual that I am. There still in the box.
From what I've heard, zero drone.
Old 05-15-2013, 05:30 AM
99corvette's Avatar
Sounds like a good concept! It would just suck when that valve sticks or fails. Kinda seems like the mufflers the c6 zo6s have with the valves that open after 3k Rpms
Old 05-15-2013, 05:40 AM
Brian396's Avatar
After looking at it a little closer I don't know if there is room for it where the resonator is?
As far as it failing, its all SS so I would think it would last. I know they had issues with the spring when they 1st came out, but I haven't heard any bad reviews since they revised it. I believe there is a lifetime warranty on them?
Old 05-15-2013, 05:44 AM
99corvette's Avatar
Oh ok missed the SS part. Yeah I don't believe there would be room. I would be interested in hearing a GXP with the stock mufflers replaced with a set of those
Old 05-15-2013, 11:55 AM
Moderator
91parkave's Avatar
Are you using the stock piping and welding on mufflers?
Old 05-15-2013, 01:38 PM
blkchevyz's Avatar
bet your just hearing it when it goes into 4 cylinder mode.
Old 05-15-2013, 04:15 PM
99corvette's Avatar
No DOD is turned off. And yes stock piping just swapped mufflers
Quick Reply: Exhaust Drone
