07 Grand prix GXP, brakes suck.
Old 07-11-2013, 09:48 PM
muxlt1's Avatar
Default 07 Grand prix GXP, brakes suck.
Girlfriend has a 07 GP GXP. The brakes squeal during braking 70% of the time. She had an inspection done by a GM dealer said everything was fine pads were 60-70% life. Now is it true these brakes just squeal from factory? She hates the fact she has a 30,000km on the car and it squeals.
What will fix this? non-slotted rotors? ceramic pads? Dealers for these parts?
Old 07-11-2013, 09:54 PM
Moderator
91parkave's Avatar
All depends are the rotors glazed over? Are the pads glazed as well? Usually those are the things that can cause the squealing.
Old 07-11-2013, 10:00 PM
muxlt1's Avatar
On the mechanics report it said the rear rotors "were discolored"
Old 07-11-2013, 10:54 PM
lVloses's Avatar
It's the metallic pads. Get ceramic and it won't squeal and you won't have all the brake dust buildup.
Old 07-12-2013, 09:14 AM
The_Madcat's Avatar
Not necessarily, I had raybestos ceramics on and they squealed like a stuck pig and all sorts of brake dust. They lasted about 4k miles before I had enough and got some OEM Delco pads. Much better now.
Old 07-12-2013, 12:43 PM
GXP25's Avatar
Get the ACDelco ceramic pads for this vehicle.
You might also want to add some brake anti-squeal paste between the backside of the pad and the actual piston.
Old 07-13-2013, 08:08 AM
Rob
Rob's Avatar
Mine did the same thing and I replaced the pad with Delco ceramic and it went away.
Old 07-13-2013, 10:33 PM
UseAsDirected's Avatar
Putting some lube on the metal clips that hold the pads in helps, too. They squeal like mad when they vibrate.
Quick Reply: 07 Grand prix GXP, brakes suck.
