Consensus on GXP rear camber
I've noticed some wear on the insides of my rear tires, just as everyone else states too. I'm wondering if theres any way to prevent this without camber bolts? I'd like to keep it close to stock handleing....maybe the alignment or toe is out of it?
I see all kinds of other vehicles on the road with a lot of negative camber and they all seem to keep their tires just fine.
It sucks to waste a perfectly good tire since only the insides of mine are worn whereas the rest of the tire looks brand new...
I've been wondering the same thing. I noticed the camber, but not any excessive wear on the tires (granted they're fairly new, probably put on shortly before I bought the car).
The wear isn't crazy, just a little more than the rest of the tire so I'd like to keep it close to stock. I'll go get an alignment done atleast though, as I have read it could actually be the toe angle and not the camber.
I haven't noticed a crazy amount of extra wear on the inside of my rear tires.
However, I do look at it as a reason to take spirited curves and such to even the wear out.
Might as well use the whole tire. You can also rotate the tires side to side when they are starting to show wear on the inside by flipping the tire around or having it mounted on the other side. Then the inside becomes the outside.
Technically if you have to much negative camber then your vehicle is not handling they way it was intended to by gm... With that being said the coupe tenths of a degree won't be noticeable but will drastically alter the way your tires wear.
I work at a dealership and recently completed my factory training for suspension geometry but with that being said in the performance side for racing purposes camber is generally added a bit to help with cornering.
When I got my impala the back tires were worn to the cords on the inner edge but the center out I had a even 7/32nds so I corrected that right away cause my car is more daily driven then track driven
That has more to do with age than anything. My tires might only be a year old and the inside is worn more than the outside, but not worn out so I have them rotated. Its not a problem. Esp if the "inside" is now the outside and rarely if even coming into contact with the pavement.
Ya I hear ya. I agree with duramax though as my tires aren't that old either. I bought the car used a year and a half ago. The tires looked like they were brand new as there was no uneven wear yet.
I did the switch suggested and so far so good.
Thanks for the input. I'm gonna get an alignment done first.
Check out this thread: https://ls1tech.com/forums/ls4-perfo...nt-issues.html
The guy in there who works for GM said it all had to do with his Toe angle. So I'm going to try there first. Only because I would really like to leave the appearance and handling of the car as close to stock as possible. If that doesn't work then I'll be getting camber bolts with my next set of tires lol.
Anyway, did it completely remove the camber? And did you notice different handling?
As much as it sucked I sort of want a little camber still just to keep with the whole performance thing of the car.
