Rear speaker replacement
The rear speakers on my 2006 GXP have gone bad and I need some ideas on aftermarket replacement speakers and possibly how to wire them. It has the Monsoon system and I noticed the plug for the speakers has four wires going to it. I realize that two are for the woofer and two are for the tweeter. What's a good speaker to replace the factory speakers with and is there a trick to wiring them in? I've searched came up with a little info and I've even called Crutchfield but they were not much help. Thanks for any info on this.
I havent done it yet on mine, did it on my other car with the factory pioneer 200 watt amp. As far as I am aware, the lows are powered by the monsoon amp and the tweeter is powered by the head unit, thats the reason for the separate wiring. Ill have to pull up a wiring diagram to verify the colors, but you should be able to wire them specifically to the new speaker as they are arranged on the factory one. Probably will require some soldering though. Just make sure you only buy the 2-ways.
Here is a thread on another board that may help, I have not tried this yet but could be a future mod. Lots of confusing info out there about how to wire any speakers up using the factory monsoon amp. Use at your own risk
http://www.g6performance.com/forum/s...ad.php?t=18003
pigsticker how do the wires from the connector route to the voice coils? I see two going to the main voice coil wires, where are the other two going, are they seperated? Is the tweeter wires runned directly to the harness connector.
These Kenwoods(5 way) I believe also have the 4 posts to make installation possibly easier. I have used Kenwood in the past, they are a decent mid grade speaker. I have the Kenwood head unit, most likely with my upgrade I will use these as well as matching door speakers.
i got infinity kappas all way around but i went to aftermarket amp,good thing i saved my monsoon as my daughters amp went out on her g6 and plugged right in,i SAVE everything lol
Then that's basically how you will have to rewire whatever speaker you use to replace it. Use a 2 way and it will be a simple install. You probably could desolder the existing harness on the OEM speaker and use it on the new speaker.
No problem, lemme know how it turns out, the wiring job should be reletively simple, should be able to disconnect the tweeter at the connector post on the speaker without having to touch any of the cones. Just make sure you heat shrink the wires since they will now be free to move. Splicing the old connector in should make it simple work as it should just plug in to the existing harness afterwards.
