power steering rack mystery
Old 05-08-2016, 11:43 PM
spawne32's Avatar
Default power steering rack mystery
Just replaced the rack on my 07 GXP, however the wheel now turns too much from lock to lock and triggers the steering angle overlimit code. Seem's to be that they sent me the wrong ratio steering rack, as I have found out that there were several different ratios available for the w-bodies from 97-08. However, after pulling the PN's off the old rack, i cannot find ANYTHING about this 07 GXP rack that cross references to the aftermarket rebuilds available to purchase. One or two come up on ebay but they are non magnasteer models. Has anyone run into this problem with the GXP?
Old 05-09-2016, 06:30 AM
Moderator
91parkave's Avatar
Did it come installed with inner tie rods and have you got a alignment yet
Old 05-09-2016, 08:49 AM
rottonj's Avatar
Can the factory rack be rebuilt with some kind of seal kit or is there a service available to send in ?
Old 05-09-2016, 09:44 AM
Moderator
91parkave's Avatar
I had zero issues with my rebuilt unit
Old 05-09-2016, 10:06 AM
rottonj's Avatar
People who have done this should post some part numbers if they have them so we know what works and what doesn't.
Old 05-09-2016, 10:17 AM
spawne32's Avatar
Yeh, its a reman unit from detroit axle, came fully assembled, I put new outters on it and had it aligned, it sets the C0710 code right as you hit full lock on either side. Any point inbetween and its fine. According to what I pulled from the atsco catalog, it looks like they sent me a buick regal magnasteer rack which is a full 3 turns from lock to lock where as the GXP rack is 2.8 and the 03 GTP is 2.7, but the GTP rack is also an inch shorter on the body for some reason, i would have noticed that when I sat them next to each other.
Old 05-09-2016, 11:51 AM
lVloses's Avatar
Did you get it aligned? When I did mine my steering wheel position sensor was off from what the rack was saying and so I was getting a C0720. Had a friend with a Tech 2 reset my sensor for me and everything worked like a charm after that.
Old 05-09-2016, 12:50 PM
spawne32's Avatar
Had it aligned, its weird it only the triggers the code if you go the full rotation to either end, soon as you hit the stops then it detects it being out of spec. The mechanic I took it too said that he was unable to do a calibration on it, and from what I read the sensors don't calibrate, they are plug and play as long as they are installed in the correct position. You were able to have a zero point cal done with the tech2 however? What year is your car and what model?
We are theorizing that because they sent me the rack with the larger turning radius (3 full turns lock to lock) that i am going outside of the steering angle sensors calibrated range. This is what ATSCO lists for the 3 different racks that are visually identical.
Problem I think im having is these low budget rack rebuilders dont specify ratios, they take in a ton of cores and only sort them by year range and with or without magnasteer. Looks like what I got is the regal rack with the 3 turns when I should have the GXP rack with 2.8. So I paid the extra money and ordered directly from atsco model 64137.
Old 05-09-2016, 12:52 PM
spawne32's Avatar
Has anyone also had a subframe alignment done before? We dropped the subframe yesterday to check this problem out and it threw the alignment off again, im worried now that my subframe could be significantly off spec.
Old 05-09-2016, 02:04 PM
Moderator
91parkave's Avatar
Half inch drive in both alignment holes on passenger side as you tighten the sub frame. Get dead nuts everytime.
Old 05-09-2016, 03:05 PM
lVloses's Avatar
Yes they have to have the specific software or whatever for their Tech 2, tried having it done at the shop when I got my alignment done and they said they couldn't do it. Drove it to my friend's shop and it took all of a minute to reset it to 0 and it was working like a champ again and no code.
Old 05-12-2016, 02:15 PM
spawne32's Avatar
quick question for you guys, how many total turns do you get lock to lock, specifically GXP guys? With this rack i have in right now, im getting about 3.5 turns lock to lock which is well over any spec that i can find.
Old 05-12-2016, 02:36 PM
rottonj's Avatar
Mine seems to be less than 2 1/2, factory rack.
Old 05-12-2016, 03:33 PM
spawne32's Avatar
yikes lol
Mike The Canadian's Avatar
I should go figure my super out; whatever it is it doesn't seem like a lot and it's very twitchy (in a good way)
Old 05-12-2016, 03:45 PM
rottonj's Avatar
yikes lol
What is spec?
Old 05-12-2016, 04:22 PM
spawne32's Avatar
What is spec?
2.8, but id rather be under estimated then have that many turns OVER spec lol
Old 05-12-2016, 04:25 PM
rottonj's Avatar
Ok, yea mine doesn't quite get to 2.5 so I guess I'm good.
Old 05-12-2016, 09:43 PM
spawne32's Avatar
atsco rack came in today, noticeably better quality then the one i put in, ill never use detroit axle again. Line's were all brand new, entire unit was bead blasted and recoated, same PN's as my old rack, boots are alot better on the ends and the tie rods are heavier duty. Came much better packed as well.
Old 05-13-2016, 06:13 AM
rottonj's Avatar
Sweet. the fun begins, again lol. ****** Detroit Axle, I didnt really care for their hubs either but they were inexpensive.
Quick Reply: power steering rack mystery
