ProSport 60mm Premium EVO Wideband Digital AFR Gauge Install Thread
So I finally decided, its time for a permanent wideband install. Got tired of having to get under the car and hook up my handheld everytime I had to go back and make a tuning adjustment. I wanted something clean that fit into one of the vent pods, not to mention I wanted it to match the rest of the gauges. I finally settled on the prosport EVO digital wideband kit. Not only because of the gauge setup, but because it utilizes an LSU 4.9 sensor this time around, instead of the old LSU 4.2 sensor that innovate is still selling as "state of the art". It's faster, and more accurate then the old 4.2 which is what im all about. Great thing about this is that its COMPACT! the controller is litterally like 1" x 2" and can fit anywhere behind the dash. Going to be documenting the setup briefly with a few pics for everyone, this is a pain free install and very easy to do.
Here's a small blurb about why the LSU 4.9 is superior.
http://www.ecotrons.com/technology/b...su_42_sensors/
heres a video of the operation, it does display in red too!
Very easy to install, you pull the side panel and remove the screws that hold the vent pod assembly onto the dash, you can drop the lower ever so slightly and the whole thing will slide out. The actual vents are held in an assembly that is clipped in, unclip it, and remove the top vent. Use the bracket to mount the gauge securely in the plastic dash piece, some modification may be needed to make it mount well against the back of the plastic. Then carefully slide the vent holder back over the gauge and into the clips and snap it in. Drill a small hole large enough to get the harness through in the air duct, and run the wires through.
more to come...
more to come...
Prosport AFR Wideband Air Fuel Ratio kit gauge 60mm Evo Series LCD Display 4 Colors Peak & Warning - YouTube
more to come...
more to come...
