Help!! Need advice ASAP on LT4 heads?'s
Got motor tore down and I was lookin at my heads and they look like stock LT1 heads The car had LT4 heads but maybe when I took it in to a shop not (mentioning any names because they are not in business anymore) did a lil swaparoo on me. I forgot what part # and what distinctive feature can make my tell that they are LT4 heads.. If they are not should I just keep them and port them or spend the money on AFR's or AI's. New motor goal is 500rwhp I know it can be acheived with good port work on LT4 heads if these are still LT4 heads
Thanks lemme know ASAP
I would go with AI ported LT1 heads before LT4s or AFRs anyway.
I think you are setting a goal outside a reasonable range for your apparent experiance level though.
AI had done 500+rwhp on LT1 castings, heads and intake, but the average guy is not going to put it all together well enough to reliably hit that number.
They are stock LT1 alumminum castings that have been worked a lil . I am going to reassemble them and sale them ..
I just purchased some trickflows 195cc 2.02 intake with 1.60 exh I am going to have a machine shop port them and the intake.
I was told that they were better than AFR's.
Do you think I made a good decision?
I understand what you have said in your previous posts about the stock castings ported would give you good power and there is no need for aftermarket heads but like my machine guy said the stock heads will eventually limit you. I was lookin at these things and it doesnt look like they would handle a lot of spray .
I am just pissed because all this time I thought I was runnin around with LT4 heads it appears that a shop may have swapped them with these stockers when I took it in 5 yrs ago to get an exhaust leak fixed because the guy that sold me the car showed the flow chart and receipts before I bought it 8 yrs ago when I was a noob .
OK forgot the 383 thing.
I will say I would rather have the Trickflows than LT4s based on results.
If you want to succeed here you need to learn to seperate bench racing from actual results. LT4s and AFRs are king in bench racing land.
Be aware though "ported" does not mean a thing. Two guys I know have cams from the same company, one has 87 octane tuning and the smaller of the two cams, the other has max effort heads from some local shop, complete with coatings and everything, tuning from a "ruputable" but in reality bad porter, and has deeper gears and stall. Screwed up thing is they run the same ETs and MPH. So there are MAJOR issues in the tuning and heads on the more modified car, just one of them should not be able to explain the huge lack of power.
Seems like alot of beginners always assume bigger is better for everything. A big cam is great.... if your car is built and tuned to take advantage of it. Its not about getting all the biggest parts you can get and slapping them together. Its the combo. Think about it like street fighter. Combos > large single attacks :-)
