New lt1 owner
Old 10-13-2008, 08:27 PM
Adison's Avatar
Default New lt1 owner
hey whats up guys my name is adison I'm 20 years old and live in good ole Paducah Ky lol...I just recently purchased a 95 camaro z28 6 speed the car is stock other then the bbk 58 mm tb i put on. I just recently broke it i was shifting into 3rd and my clutch stuck to the floor So i get the car home and call up a couple of my buddies and ask them what they think it might be because i didn't know. The guy i purchased the car from said it had a brand new hays clutch, so i didn't even think it would be the clutch.. so far I've replaced the slave cylinder, i had a steel braided clutch line made because the other one had a hole in it.. which i thought was the problem. and also i replaced the clutch master cylinder. Its still has no pressure after i bled it for like 45 mins.. but the weird thing is it wont go into gear at all and when i try to start the car up with the clutch engaged it wont start it turns over a lil bit.. but then quits. But when i start the car up with out the clutch pushed in it starts right up but when i push the clutch in it makes a weird noise comin from the tranny and almost dies its really weird.. so me and my buddies think it is the pressure plate what do you guys think... lol i hate for my intro to be like this but im just in a big mess and want to drive my car again lol
Old 10-13-2008, 08:37 PM
pooogy's Avatar
Welcome! I'm from Jackson, Missouri (right next to to Cape Girardeau)
I don't know much about manual transmisions. Maybe try looking under the manual transmission forum here.
Old 10-13-2008, 08:46 PM
Adison's Avatar
ya ill look into that ya i got the t56 o ya the guy before me that had the car blew the motor up adn replaced it with another lt back in 06
Old 10-13-2008, 08:55 PM
lifeisgood's Avatar
if the car is having problems starting maybe your clutch switch is bad. i broke mine shifting hard.
but sounds like there might be a lil more damage
Old 10-13-2008, 09:13 PM
Adison's Avatar
where is the clutch switch located and what part of ky are you from? if you dont mind me asking lol
Old 10-13-2008, 09:44 PM
IMgettingLS1's Avatar
i broke one before i think it was called the clutch fork. id guess you messed up the pressure plate as well
Old 10-13-2008, 10:02 PM
94CamaroZ28SS's Avatar
I had my throw out bearing go out that caused a wierd noise in the tranny when i pressed the clutch in, i still had pressure though that was in my 92 Camaro RS!
Old 10-13-2008, 11:15 PM
jarretthise's Avatar
YOU NEED A NEW CLUTCH BRO!!! those hayes clutches are really touchy...its in or out...dont drag your clutch time out man....its not good on it
Old 10-13-2008, 11:16 PM
oh one more thing!! not your clutch switch...ill tell you that right now
Old 10-14-2008, 09:02 AM
Adison's Avatar
ight ya man i appreciate it i was goin to put a new clutch in anyways because i was goin to be replacing the pressure plate.. so what clutch do you guys think i should invest in. I dont want an oem replacement or anything somethin a little more beefier lol
Old 10-14-2008, 06:07 PM
Fast93Z's Avatar
centerforce dual friction i love it, it never fails and is easy to drive with and holds a lot of power
Fast93Z's Avatar
or might i suggest a spec clutch
Old 10-14-2008, 07:33 PM
spec is a good clutch!! its what i have now...ppl will tell you they are hit or miss with the good and bad but i love mine....its awesome....its a stage 2
Quick Reply: New lt1 owner
