Highest HP Hyd roller guys?
What the highest RWHP out of a hyd roller with LTX? Tell me your setup
I am building a 383 with Trickflow heads and ported LT4 intake built bottom end with 11:2:1 comp. I am hoping to get atleast 450rwhp. Am I dreaming or can it be done with what I got thanks.
Oh this is through a 12 bolt and 6 speed.
no your goals are within reason. Who is going to do the work on the heads and intake? How big of a HR cam are we talking?
I ask because you may even break 450rwhp with the right setup. Will it have every supporting mod?
RayMac from RayMac engines is going to do all the porting. He is one of the best in Texas in My opinion and also a friend of the family. The cam will have about a .600 lift on it on the Trickflows 195cc 2.02 int and 1.60 exh which will be worked over along with the LT4 intake.
I could hit that place with a football from my house. There chicken and catfish is like crack. Hell when my cat runs away I always find him passed out next to the babes dumpster couple days later. That place is the SH*T
Yup.... it has been done, will be done in the future...... fairly easy...
I had ported stock castings, SRP pistons in a 6" rod 355... stock crank, LT1 manifold, long tubes, etc......
Put down 422RWHP NA..... wasn't all that nasty of a hydro roller either..... And it wasn't tuned to it's optimum either..... It would have made 440 easily with some more time in the DFI tune....
As you can see in my sig, I hit 445rwhp with my setup. As others have mentioned, 450 will not be a problem with the setup you will have as long as everything is done right.
Nice looking car too.
By "maxed" does he mean 80-85 duty cycle or does he mean 100%?
My understanding is that pushing them too hard can result in a distorted spray patten.
A little too big seems better than "just maybe enough" to me.
I'm not talking 72# where a 36 is needed, but 42 vs 36 shouldn't be an issue.
That's an interesting theory.
He says that they will be at 80% but the nitrous will max them out. What are you using?
