Going back to Muncie Dragway tomorrow
We are going to try to get this thing in the tens. DA at Muncie right now is -1350! Hopefully the weather tomorrow is like tonight and the traction is good.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Muncie results from 22 oct 08
1st pass 60' 1.484, 330' 4.511, 1/8 7.035, mph 97.16, 1000' 9.230, 1/4 11.094, mph 120.95
2nd pass 60' 1.533, 330' 4.549, 1/8 7.076, mph 97.01, 1000' 9.273, 1/4 11.138, mph 120.88 These were back to back passes with no cool down. The track started to go away, the temps dropped big time!
3rd pass 60' 1.513, 330' 4.483, 1/8 6.973, mph 98.48, 1000' 9.146, 1/4 10.994, mph 121.49 Finally in the tens!! There was over an hour and a half between the second and third pass. The last two passes I couldn't hook, the DA was now around -430 and around 43 degrees. She would have been quicker with a prepped track but I am happy with a 10.994!!
__________________
Interior is still intact, there's more weight to be found if Jon wanted to gut it. 170 lbs came out of the front and 45 lbs out of the rear. Bob
Thanks for the good words guys. I think it's time to borrow the tires from Bob's car to see how it reacts with drag radials. I'll keep you posted on that.
Josh, the Formula weighs 3241 with the tank drained.
It would be in that range with the interior out with some good traction. We need your car for that!!
Originally Posted by Beaflag VonRathburg
That's the stock engine single power adder one we talked about a while ago. If I remember correctly it's in the 10.86 range.
__________________
http://lsx.streetfire.net/video/9a44...45001f56d2.htm
Video from last night.
Jarretthise, hope to see you there. Bob
Run 1. 60'-1.452, 330'-4.423, 1/8-6.914@98.43, 1000'-9.083, 1/4-10.927@121.96
Run 2. 60'-1.482, 330'-4.456, 1/8-6.953@98.14, 1000'-9.128, 1/4-10.978@121.62
Run 3. 60'-1.452, 330'-4.415, 1/8-6.902@98.53, 1000'-9.070, 1/4-10.914@121.90
Jon
__________________
Man Bob, this is like having a live feed....stuff is posted while I'm still racing!! Cool, thanks. Quickest run for the night was a 10.91. Here are the three passes...she is still holding together and running strong.
Jon
Jon
lol, no doubt! Next time though, give me the results from the return road so I can get them posted up a little sooner! Bob
