First 1/4 run w/ 383
Very nice! What's you're setup? (heads/cam, etc.)
Sucks about the cleanup time. Some people don't know that when they break it's a bad idea to drive down the whole track anyway.
Cam specs. 234/238 .576/.595 114+4
110 ICL
7* IVO/ 47*IVC
Stock heads maxed out by LPE 2.00 intake--1.56 exhaust. Stock intake ported and polished. 58mm LPE throttle body.
110 ICL
7* IVO/ 47*IVC
Yes. Stock 3.42s Spun some off the line. 16lbs of pressure. It was very cold. Probably about 40 degrees. Good for power, bad for traction. I also have a Spec stage 3+ clutch that I used for the first time. It is very driveable on the street but it seemed to grab hard all at once on this run. A bit of a learning curve to figure out how to launch with it. This was also my first trip to the strip in two years!
(and be the guy everyone is staring at for having oiled down the track and ruined their night of racing)
It might not be a bad idea to start with a rear end up upgrade before improving traction or weight transfer.
