PITA to change oil pump on LT1?
Old 11-02-2008, 06:12 PM
02RedWS6RamAir's Avatar
Default PITA to change oil pump on LT1?
So is it a real pain to change?
Thanks!
Old 11-02-2008, 06:37 PM
wrd1972's Avatar
Uh,yup.
Old 11-02-2008, 06:46 PM
damn........
Old 11-02-2008, 06:47 PM
In-Zane Moderator
ZONES89RS's Avatar
Meh, for a inexperienced individual, yea, for those that have done it...it is just the fact of doing it that bothers me.
Old 11-02-2008, 07:02 PM
Jditlfm's Avatar
Its not bad if you have done it before. Its a matter or unbolting motor mounts lowering K member, attaching the engine to a engine hoist and jacking up the engine. Then drain oil, undo the low oil level sensor, starter, unbolt pan There is the oil pump. Atleast for my 6 speed thats how i have to do it.
Old 11-02-2008, 07:04 PM
Badazz 97 TA's Avatar
ha, couldnt agree more!
disconnect battery. pull the two big motor mount bolts out. jack the engine up as high as it will go. take off starter, un bolt the oil pan. and pull it out. may have to turn the crank to move the weights in order to actually pull the pan. not real hard. just a PITA
A4 or m6? not sure if you can do it with a m6 without having to pull the trans out. A4 no problem since its more round shape then a m6
Old 11-02-2008, 07:09 PM
Jditlfm's Avatar
It wont come out without either lowering the K member or disconnecting the trans in a 6-speed I tried trust me.
Old 11-02-2008, 07:11 PM
Its not bad if you have done it before. Its a matter or unbolting motor mounts lowering K member, attaching the engine to a engine hoist and jacking up the engine. Then drain oil, undo the low oil level sensor unbolt pan. There is the oil pump. Atleast for my 6 speed thats how i have to do it.
That sounds like a major pain!
BTW car is an auto.
The reason I'm asking is because my oil pressure seems to be low. I'm not sure if it's the sending unit though...(pic)
Old 11-02-2008, 07:16 PM
i would replace the sending unit before i tore off the oil pan. little easier. and if it doesnt fix it then change the oil pump. luckily you have a a4. you WONT have to drop the k-member.
Jditlfm's Avatar
put a mechanical gauge on it 1st. But low oil pressure can come from excessive bearing clearances. I would bet a oil pump is not the cause of that if it is fact an accurate reading. If it does that only on hard stops and hard acceleration, then there is a good chance the pickup fell off.
Old 11-02-2008, 07:17 PM
MTBSully's Avatar
BTW car is an auto.
dont go pulling the pan if it might be the sending unit! Ive done it before and somehow i managed to do it with an m6 without touching the K member. Just jacked up the motor as far as it would go. How hot is the car when the pressure is like that?
Old 11-02-2008, 07:18 PM
Jditlfm's Avatar
Looks like its just below 185 degrees when the oil pressure is that low. IDK how the hell you managed to get that pan off with out lowering the K member. I had mine jacked up so high it was on the cowl and starting to bend it and i still couldn't get it to clear the trans.
Old 11-02-2008, 07:27 PM
IronOutlaw's Avatar
I had to drop the k member to pull my pan out of my car. Its an A4.
Old 11-02-2008, 07:44 PM
slingshot928's Avatar
Didn't have to drop the k on my car, A4, also put a canton pan back in. It was a tight fit and alot of swearing, but it went in. Dropping the k means realignment.
Old 11-02-2008, 07:47 PM
96capricemgr's Avatar
Oil pumps are extremely reliable, the chance it would cause low oil pressure is very low. Verify with a mechanical gauge and if indeed low it would be a much better assumption to belive it is bearings.
Old 11-02-2008, 09:15 PM
After driving on the expressway for about 40 minutes 65-70MPH
So does that mean the motor's shot?
Old 11-02-2008, 09:20 PM
Forgot to ask....
Is it likely this condition is nothing more than an oil pressure sending unit on it's way out?
Old 11-02-2008, 09:33 PM
I have not seen a sender fail by reading a little low, just by being erradic. Best bet though is to verify with a mechanical gauge before doing anything else. Can get a basic one at almost any parts store for $15-20, might get the copper tube kit for the extra $10 too. I would not plumb it into the car. Do a temporary install attaching it somewhere between the hood and windsheild and go for a drive.
Old 11-02-2008, 09:47 PM
Where do you plumb it into besides the sending unit?
Old 11-02-2008, 10:01 PM
Jditlfm's Avatar
Courtesy of shbox. This is where you want to go to. I checked my electric gauge with a mechanical and mine was dead on.
Quick Reply: PITA to change oil pump on LT1?
