i need gear help
i need gear help
my 95z came with stock 273 gears im planning on changing them to 373 gears do i need to change my carrier or can i just change the gears over im going with gm 373 gears and the installation kit that comes
with cover gasket crush sleeve marking compound and brush pinion and carrier bearings pinion nut and washer pinion seal thread locking compound
sealer and shims thanks in advance
So I'm trying to help Baylove out with his swap fellas.. From what he has told me, he has the stock 2.73 gear ratio and he's looking to change them out to a 3.73 gear ratio. Now from what I understand, the 2.73 Camaro's came with a different carrier and to swap gears weather it be a 3.23, 3.42 etc etc you would have to get a 3 series carrier that came in the Z28 that had 3.42 and so on. True?? If so, can anyone on here help a fellow f-body owner out with his swap or at least steer him in the right direction? A local shop has told him he wouldn't need a new carrier to go to a 3.73 but from what I remember you do. I'm no gear expert when it comes to Bay's situation.
Elliott
Elliott
the shop that i called mentioned if i went with a thicker gear that i wouldnt need a 3 series carrier like
dafhturbo said
these are the gears and the install kit i was looking at
http://www.speedwaymotors.com/p/3772...nd-Pinion.html
http://www.speedwaymotors.com/p/3785...tion-Kits.html
