need ideas on were to put the box
were do you all locate your boxes. if you have any pics to show that would be helpfull. the only place i can see to put it is were the battery is and relocate th battery to the truck. thanks for any ideas
ok thanks i have a adjustable pressure regulator, and a 255lph pump on order. is there anything else i may need for my hot cam kit and headers. will i need any bigger injectors?
its not the finished pic but i had to move the power steering res over a bit and i added some battery terminals above the box..it turned out pretty well. Eventually I'm gonna pull the ac box and mount the ignition back there.
riceburnerz28 : what dampener do you have on there? in that pic?
bad99transam : I saw a guy had his box mounted on the flat spot right next to the fuse box. Here, I circled the spot. If you did the fuel line mod so they are out of the way it leaves that spot free and clear.
