elbow to fit over a 58mm throttle body
my stock elbow does not fit over my 58mm throttle body will any cold air kit work or does someone know of a special elbow that will fit
I mean, aren't they the same size? Just ported bigger in the middle? Maybe I'm wrong.
no they are definately different sizes my stock elbow fits easily over the tb but it is not close to fitting over the 58mm and i found a cold air intake that comes with the elbow and everthing
i just replaced my trickflow with a 1le and i had to take the clamp completely off to put the elbow on the tb. it wouldnt slide on even with the clamp on full loose. for the record my trickflow was WAY smaller than the 1le.
its just a cheap no namer but i dont have $250 to spend on a cold air kit
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
im kinda confused with this thread r u talkin bout the elbow fitting the tb? or the cai? if u want a new one i bought the granniteli one its aluminum and wont rip but it gets hot
They're the same It's just the cheaper "elbow" you have that the rubber isn't stretching as much. Had you gotten a real LT1 elbow, you wouldn't have this problem.
If you want a CAI and don't have the money to spend $200, buy one used on here for about $80. If not, go with the Ebay one but you mite have fitment problems.
yea this is just rediculous, dude the exterior size of the throttle body is exactly the same, and for the record i got a 1LE elbow and it was a PITA to put on, used a little lube and it slid right over the throttle body. just takes some time and elbow grease for the first couple times.
what throttle body are you working with?
Use a little Vaseline and some warming lube...I mean a heat gun...don't ask me how I know, but it works! Seriously though I have used Vaseline on some hoses I thought would never go on in a million years (Like 1 1/4 over an 1 1/2 fitting) and a little Vaseline and heat did the trick.
meat gazers
"used a little lube and it slid right over the throttle body. just takes some time and elbow grease for the first couple times. "
"Use a little Vaseline and some warming lube...I mean a heat gun...don't ask me how I know, but it works! Seriously though I have used Vaseline on some hoses I thought would never go on in a million years (Like 1 1/4 over an 1 1/2 fitting) and a little Vaseline and heat did the trick."
I am still waiting to see.... use the his KY on the TB and the Hers KY on the elbow.
GO GET LAID GUYS
GO GET LAID GUYS
