freescan?
Old 11-16-2008, 03:33 PM
pat95z's Avatar
Default freescan?
I am trying to load freescan on my laptop and a window pops up saying it is loading the setup wizard, but the wizard never pops up. A blank window does pop up that says andys name at the top but it says not responding when clicked on. Im running windows xp. Any body have this problem? Know of a fix?
Old 11-16-2008, 04:17 PM
camar0corey's Avatar
I'm using it with XP, no problems. Wish I had some advice, I downloaded it from his site and it installed just fine. Maybe the download file wasn't complete or something strange?
Old 11-16-2008, 07:28 PM
ThreeHonks's Avatar
im not too sure, but i would disable the pop-up blocker on your computer. I have a similar result if I try to pull up a window that is a pop-up. If that doesnt work I would try to re-download the file
Old 11-16-2008, 09:49 PM
MTBSully's Avatar
sorry to hijack here but what is freescan? I have the cable to hook my car up to my laptop Is it similar to a datamaster setup? Anyone got a link? Thanks guys
Old 11-16-2008, 10:54 PM
pat95z's Avatar
Thanks for the ideas. Ive tried turning off the popup blocker and all of my security system with no results. I downloaded it form two sources a few different times. I guess its probably something in my comp.
Its a data logger similar to datamaster.
http://www.andywhittaker.com/ECU/Fre...0/Default.aspx
Theres the link let me know if the program loads for you.
Old 11-17-2008, 08:23 AM
I mostly sure it doesn't work with OBD-II.
Old 11-17-2008, 09:02 AM
ThreeHonks's Avatar
no it says that right on the download screen, OBD-1 cars only!!
Old 11-17-2008, 09:08 AM
Jditlfm's Avatar
I downloaded it for my obd1 car I got it installed and everything but i could never get it to work. It would never connect. I said screw it and i bough data master. Works great haven't looked back sense.
Old 11-17-2008, 11:12 AM
MTBSully's Avatar
my car has an OBD1 computer with tuning
JD what datamaster program did you buy?
Old 11-17-2008, 12:03 PM
Well freescan is free, so just download it and try it out.
One trick to get it to work is have it listen, after it reaches 10,000 on the counter hit interact, seems to work fine for me. Autoparts stores around here don't have a OBD-I reader, so I mostly use it to pull trouble codes.
Old 11-17-2008, 12:44 PM
ryle's Avatar
Freescan is free, yes, but so is datamaster for 20 sessions. I personally like datamaster, but my free sessions have expired, so now it's time to downgrade
Old 11-17-2008, 05:36 PM
MTBSully's Avatar
where can you download datamaster?
Old 11-18-2008, 11:09 PM
MTBSully's Avatar
anyone know where u can get the first 20 sessions of datamaster free?
Old 11-18-2008, 11:25 PM
Jditlfm's Avatar
here ya go. http://www.ttspowersystems.com/DataM...downloads.html
Old 11-19-2008, 10:41 AM
riceburnerZ28's Avatar
will any of these programs work with the Vista os ?
Old 11-19-2008, 11:07 AM
MTBSully's Avatar
i hope so becuase thats what i've got
Old 11-19-2008, 12:32 PM
ryle's Avatar
I don't know about freescan, but I can say that Datamaster will work, because I have it loaded on my desktop so that I can review my runs.
Old 11-19-2008, 03:10 PM
MTBSully's Avatar
good to know. Thanks
Do you keep your laptop in your car and review runs? Or do you have some sort of palm pilot instead?
Old 11-19-2008, 03:13 PM
ryle's Avatar
My laptop is a work issued computer, so It's in the car a limited amount of time. I usually just collect some data on my way home, save it, then load it on my desktop to review the data.
ryle's Avatar
now if I can figure out how to interpert the data, and make changes I'll be in business
Quick Reply: freescan?
