true duals or stick wit cat back?
ok i know this is discussed ALOT but i want to know opinions and pros and cons. im starting a 383 nitrous build our goal with the car is to one day hit 9s but it will still be driven. i want to know if wen i switch the headers to long tubes should i stay with the y pipe and cat back with a cut out or get an x pipe and some mufflers. if i should go to true duals how big of an x pipe 3"? id lik all your opinions on this were trying to build a real serious car and wanna do it right the first time.
a muffler shop wont be doing any of the work we do it all ourselve we hav access to a lift so that helps so if i get the lpp headers and then the TSP x pipe and mufflers i can make them work together?
Bassani TD:
http://s21.photobucket.com/albums/b2...MPSTRIdle3.flv
Borla:
http://s21.photobucket.com/albums/b2...MPSTR_Idle.flv
Similar cams and build, exhaust and compression are different.
Borla:
Don't even waste the money on the TSP true duals. Go with a universal x-pipe kit from either Jegs or Summit. Either way, some fabrication will be needed, and you'll save a **** ton on the universal kits. I've got the 2.5" Jegs x-pipe and some cheap ebay knockoffs of the Flowmaster 10 series. Between the x-pipe and mufflers, I spent a total of around $150. I don't have a cam, just a few bolt-ons, but here's what it sounds like. http://videos.streetfire.net/video/9...ust_192864.htm
so with a little fabricating this x pipe will work cuz this would be perfect
http://www.jegs.com/p/JEGS/759968/10002/-1
and wher would be the best place to put cats since i need them stupid jersey
yea i no it will but i HAVE to i wont pass after this as it is but even the guy that said ill pass it no matter wat failed it with no cat now so unfortunatly i have to keep them. no leaded 110 race gas for me
