What a great night...
Old 12-06-2008, 12:09 AM
Huff035's Avatar
Default What a great night...
So parked my car to talk to some friends tonight and one of them wanted me to ride in his cobra and we were pulling back to where my car was and there was a puddle of antifreeze under my car...
I checked everything and limped the car home, pull in the garage and it dumps it out again...it seems only to run out after i shut off the car. Is it the water pump?
Old 12-06-2008, 12:23 AM
LT1
LT1's Avatar
Are you able to see where its wet under the car? What you last do to the car before it started dumping coolant.
One of my buddy's had a similar problem on his 97 Z28, found out at the end it was the afermarket radiator, the radiator where the hose goes over it wasnt sealing it properly.
It could be your water pump. Cant say for sure with out seeing pic under there.
Old 12-06-2008, 03:46 AM
I8ASaleen's Avatar
Pics? Location?
Old 12-06-2008, 04:17 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Was it drinking? Beer will do that....
Old 12-06-2008, 05:39 AM
riceburnerZ28's Avatar
pics would be helpful. My guess is it could be coolant hose, or cracked radiator but since u said it leaks after u shut the car off I would say the coolant levels might be too high ! The same thing happened to me and it poured out the reservoir every time I shut the engine off !
Old 12-06-2008, 06:56 AM
the_merv's Avatar
I had mine a hair too full and it decided to burp itself one time after I shut it off..lol
Old 12-06-2008, 09:14 AM
Huff035's Avatar
its been fine for a long time, checked it every so often just like i do with everything else and then last night was running my friends S R T 4 on the interstate came in town, parked to talk to some friends and it has a puddle...
Old 12-06-2008, 09:20 AM
Huff035's Avatar
It looks a little wet around the seal but that about all i can see. and its WAY too cold to lay on the garage floor right now. haha
Old 12-06-2008, 09:35 AM
Formula350's Avatar
The seal... what seal? Timing cover, waterpump drive, rear main, axle housing? heh
Old 12-06-2008, 09:37 AM
Huff035's Avatar
waterpump, sorry
Old 12-06-2008, 09:52 AM
impaled's Avatar
mine did that once and the radiator cap wasnt on tight and the residual pressure built and it leaked some coolent. i freaked out and checked everything. waited for it to cool went to fill it, checked the cap and sure enough it was loose. just a thought.
Old 12-06-2008, 11:01 AM
30th ponyslayer's Avatar
water pump couldve took a dump when u ran the srt..i know mine did during a high rpm burn out,,maybe when the t-stat is open not leaking as bad,,when u park it and pressure tries to build a little it pukes it out..but im far from a mechanic,,just a thought
-jason-
Old 12-06-2008, 11:10 AM
97LT1's Avatar
I say after parking up, pop hood and watch for where leak comes from. If you have a lot of air in the system it can burp out reservoir as well. If you overfill it, it can also come out that way.
Old 12-06-2008, 11:39 AM
crookedbowtie's Avatar
Hope it doesn't drown your opti to death.
Old 12-06-2008, 07:38 PM
impaled's Avatar
that is a definite concern. OPTI's dont like coolant much (or even moisture).
Old 12-06-2008, 10:26 PM
Formula350's Avatar
That's why I recommend to everyone doing an Opti, they replace their water pump, or at the very least put a drain line on the weep hole. Either by gluing a barbed fitting in it, or drill and tapping it and screwing a barbed fitting it. That way WHEN it finally goes, it'll **** out where you routed that drain line too
Old 12-07-2008, 02:13 AM
Toronto_LT1's Avatar
excellent idea!^^^
Old 12-07-2008, 02:29 AM
the_merv's Avatar
Anyone remember the little Ramp Mod that I did to mine?
Corey..if you read this, post a pic of the bottom of the Water Pump on that Engine I sold you..
Old 12-07-2008, 03:42 AM
tylert14's Avatar
Maybe your overflow reservoir cracked. I had a wrecked F body that didn't leak any coolant until it got hot enough and built pressure in the coolant system. It would start releasing it into the reservoir and just leak out.
Old 12-07-2008, 03:48 AM
Blacklightning744's Avatar
see what side its coming out of, it could simply be the resivoer under the battery has a leak, or like stated above the cap could be bad, i doubt its the water pump, cuz if it was leaking in anyway shape or for form the car would have a steady leak, or obvious signs.
Quick Reply: What a great night...
