studs or bolts...
studs or bolts...
How many of you guys are running +200hp nitrous on an LT1, and what are you using... Im debating between the two (bolts or studs) and torn due to bad experiences ive been reading about. i personally had good luck on two sbc's with studs, but seems LT1's dont do so swell. let me know!
I have sprayed 300 thru my motor but will be spraying 400 thru it very soon......
and I use ONLY studs...... 200 shot you'll be good with bolts. Hell 250 you could use bolts....
I just want cheap insurance and the cost between the two is minimal....
well... unanimous decision here huh. yeah, i was thinking about it today and said to myself that as often as my k-member comes out its a no-brainer. dont plan on pulling heads in the car. thanks guys, ill post up results in a bit when i get this thing back together. had some unfortunate family issues come up, so put the plans on hold. btw, i know someone wants to donate a part number so i dont have to beat my head on the wall using the search function
