10sec allmotor LT1! questions
Well not yet, but soon! I am wanting to know if i got a 355 w/ LE1 heads, LE ported intake, comp cams 306, 1.6 RR's with 52mm TB, 30lbs injectors, and get it tuned finally plus getting a 12bolt with 4.10's would drop me down to atleast 10.70's in summer weather? I may also upgrade to a Hughes Racing4000 stall if neccesary. The times in my sig were run Houston Raceway in this weather : 50*Temp 40%Hum 30.26Baro
possible? yes I have seen some crazy times out of combo's before, but I think you will need more of a setup.
The car would need to be very light to do what you are asking with the combo listed.
now better heads, custom cam, and a very efficient drive train is more practical IMO to accomplish your goal, but it won't be as easy
gear and tuning as you listed is not going to give you the gains you want
I suggest looking at the fast list and the setups listed should help you some.
EX: my 396 with stock ported heads/intake @ 3400 race weight goes 10.89@123 1.45 60ft
I am looking for that out of my 383/t56, hope to get a 11.0 na, got 11.93 with 8 degrees of false spark retard, so I think I should be able to pull it off, and also with a 48mm TB
Looks like you have a light raceweight, so that's a good start.
My car weighs in at 3580 raceweight with driver, see sig for times.
For starters I think your cam selection could be better.. cc306 is old news. I like the 4.11's out back, but talk to Yank about their PT converters.. it's working well in my all motor setup.
I missed the race weight in his sig...that's light and in that case the combo is going to need some changes based off your current results ( if done at this weight now )
I dont see you running 10.70 in Houston summer heat with that combo, no.
I agree, I think you'll need more ponies to accomplish 10's natural.
What kinda changes are you thinkin? I may be doing a partial trade on my bike with someone that has a 355 with le1's and le intake is why im askin this. so what kinda hp do you think ill need to do this with my setup? everything in sig plus 12bolt w/4.30 and 4k stall and a Tune.
while keeping the stock short I do see it possible still or build a 383+cu with the below listed suggestions
-head update by LE or similar 2 or 3
-custom cam
-get the valvetrain in order to get some good RPM out of the combo
I say LE since I have used him and done a couple of his setups on cars and have been pleased.
if keeping it NA I suggest 4000+ stall as mentioned
gear/tire choices have to be made based off the combo
good dyno tune
-custom cam
good dyno tune
Not a fan of the over priced LE stuff. AFR it the way to go. I would be running a set if I didnt get a GREAT deal on my heads. I am running this cam in my combo and it is insane
HR-234/365-2S-12.90 IG, pulles through 7k
-custom cam
good dyno tune
-custom cam
good dyno tune
http://www.advancedinduction.com/AiPerfLT1.html
here a link to there results theres some cars runnin impressive times
i bet i can take my soon to be finished 396 with ported AFRs and single plane with a solid roller and rip the bumpers off yours...and thast with a 6 speed, with that being said you have one of the faster LE head/cam cars ive seen im not looking to get my car to 60' like mad...i want something thats going to run circles around autos on the street tho... hell with a stock motor 150 and a 6speed in a gutted car i bet i could have run close to what you run now though but coulda woulda shoulda...
