valve springs
Old 12-12-2008, 07:50 PM
andrew ws6's Avatar
Default valve springs
is this all you need for a valvespring change?
?http://store.summitracing.com/partde...w=1&N=700+150+
Old 12-12-2008, 09:33 PM
ZMONSTER!'s Avatar
Link doesn't work.
Old 12-13-2008, 08:52 AM
andrew ws6's Avatar
fixed
Old 12-13-2008, 10:08 AM
NicksTAgt's Avatar
I would recommend getting some new valve seals, maybe some locks too for cheap insurance. Thunderracing could hook you up.
Old 12-13-2008, 10:30 AM
99.9percenter's Avatar
I installed that kit and was very happy with it. It comes with new locks. I was forced to get new smaller seals which required machining to install (I did it with a hand drill and a cutter designed for the seals I bought). I also had to buy additional shims to get the proper height. Some people used shim in kit and stock valve seals with good results. I could not, maybe they vary?
Quick Reply: valve springs
