Should I replace the rear main seal?
Old 12-15-2008, 10:01 PM
koolaid_kid's Avatar
Default Should I replace the rear main seal?
I just completed my engine build, but it is still on the engine stand. I purchased a lightly used short block (I can still see the hone marks on the cylinders). It was professionally built by a shop in IL. I have spent the summer acquiring and installing all the parts (far too many to list) to make it a complete engine.
I was going through my Felpro gasket kits this weekend to make sure I left nothing out, and I noticed that I have a new rear main seal. I visually inspected the seal on the engine, and it appears to be fine. Should I go ahead and put the new one in, or keep it as a spare? I would have to remove the Canton oil pan to do so (a real PITA due to fitment issues) but I could do it. What do you think?
Old 12-15-2008, 10:10 PM
Elliott's94Z's Avatar
I've always been one to change out old parts during any kind of swap. Knowing it's a fresh part or seal in your case would give me a sense of "knowing I did it and it's been addressed." So yes, I would personally.
Old 12-15-2008, 10:14 PM
IMgettingLS1's Avatar
its one of those things thats way easier to do with the engine out and ready
Old 12-15-2008, 10:26 PM
SoxXpupPeT's Avatar
yes. i did when i did my clutch. it was a very simple and easy job. just dont scratch the wall of the block where the seal sits.
Old 12-15-2008, 10:38 PM
Moderator
BizZzatch350's Avatar
The way it work is, it should look fine on the stand, but will start leaking once every done and installed.
Old 12-15-2008, 10:39 PM
CamaroRacing12's Avatar
do it... its like a $20 part i did it with when my tranny was out...
Old 12-15-2008, 10:46 PM
the_merv's Avatar
I would do it..
Old 12-15-2008, 10:52 PM
IronOutlaw's Avatar
Im def. changing mine on the camaro this weekend when i swap trannys.
My firebird leaks bad out of it and it is a real pain in the ***.
Old 12-16-2008, 03:21 AM
Dammittall, you were supposed to say "No, you'll be fine...".
There is no emoticon for "Big Sigh".
Yeah, that's what I thought also when I realized what I was looking at. I just wanted to make sure I was not being overly paranoid.
Thanks guys, guess I'll be rasslin' that damm pan again.
Old 12-16-2008, 08:23 AM
moehorsepower's Avatar
Engine is out, you have the seal, easily changed out= No brainer...
Quick Reply: Should I replace the rear main seal?
