thinking about a new intake manifold
Old 12-31-2008, 05:34 PM
F3RR3T's Avatar
Default thinking about a new intake manifold
thinking about using a carb intake and converting it to EFI. What are the benefits to a carb intake converted to EFI?
also thinking about fabing my own sheetmetal intake. would just have to learn the math needed to do this.
if any one has any links for that im all for it.
Old 12-31-2008, 06:08 PM
96capricemgr's Avatar
How aggressive is your motor???
While this mod gets talked up most do it wrong and see little benefit.
Every knowledgable person you ask will tell you the stock intake works surprisingy well for a huge range of applications.
Old 12-31-2008, 06:20 PM
F3RR3T's Avatar
my motor is not yet built but isnt nothing special. 450 at the wheels.
mainly just hate the looks of the stock intake. i really would like to do the sheet-metal intake for the learning experience and to practice my tig welding
Old 12-31-2008, 06:22 PM
Elliott's94Z's Avatar
Well sorry but I consider 450rwh to be something special
Old 12-31-2008, 06:33 PM
IronOutlaw's Avatar
http://www.impalassforum.com/vBullet...d.php?t=213529
Go take a look at this and take some notes. Hasnt been on a dyno or at least been posted up yet, but seems very interesting.
Old 12-31-2008, 06:47 PM
That looks rather interesting
Old 12-31-2008, 07:06 PM
SLawson86's Avatar
unless you are planning on throwing gobs of nitrous to your motor, i dont really see any benefit at the 450 range. im considering it on mine, but i plan on revving it to the moon with a good bit of dope. just my .02
Old 12-31-2008, 07:07 PM
SLawson86's Avatar
oh yeah, and im doing the work myself, so its not going to cost much. im figuring max about 600.00.
Old 12-31-2008, 07:12 PM
Now I remember your other post.
Can you show any data that supports your belief you can get 450 with the proposed build???
The guy who made the dual TB intake tried the carbed intake thing and went back to stock before trying this current idea.
Old 12-31-2008, 07:58 PM
joelster's Avatar
Benefits:
1. Upper rpm (assuming you go with the Victor E)
2. Has more HP potential, ability to flow more air.
3. Opens up your nitrous kit choices IMMENSELY, and the kits themselves are cheaper. Basically just about any 4bbl carb nitrous kit can work.
Drawbacks:
1. Cost. The manifold (Victor E) is about 250-300ish, fuel rails are 75, and you will have to do some fab work to adapt your fuel lines to them. Plus you will need a custom elbow, to fit your throttle body, or you will have to run a 4bbl throttle body, along with a throttle position sensor. Don't forget you will have to convert the manifold to the LT1 head bolt pattern. You can purchase a custom elbow for 300ish from a vendor on here. Figure about a grand for everything you need.
2. low-end power will be worse than it will with the stock manifold.
3. Hood clearance MAY become an issue depending upon your elbow. Forget about running a tall nitrous plate though unless you are running a cowl induction hood, or something similar.
The only hand fabbed sheetmetal intakes that I have seen are for seriously large displacement motors. They look exoctic and cost a fortune, and usually aren't meant for cars that see any street action. Not needed at all at the hp levels you will be at. I really doubt that you will widdle away in your garage and come up with something that will make more power than a Victor EFI manifold, on a car thats around 400hp.
Old 12-31-2008, 08:12 PM
96lt1m6's Avatar
that is roughly the power Taner has and he has a "stock self-ported intake" and runs bottom 10s n/a and extremely low 9s on the spray so my qyuestion is,how restrictive is the stock intake?
Old 12-31-2008, 08:55 PM
F3RR3T's Avatar
other people have had the same results.
straight from Lloyd's site
"LT1 LE2 heads are capable of producing 370 RWHP with our small 218/224 custom cam and 410+ RWHP with our 232/240 custom cam."
and i will be talking to him about a custom cam and a full roller valvetrain.
also will be freshening up the bottom motor and going .030 over
Old 12-31-2008, 08:57 PM
F3RR3T's Avatar
have not a clue on the how restrictive it is. im mainly doing it as a project and looks. eventually i will be building the bottom end and hitting it with a 300 shot
Old 12-31-2008, 08:58 PM
F3RR3T's Avatar
ive priced all the material for a intake and im at 250 + welding rod and shielding gas
Old 01-01-2009, 08:45 AM
No they haven't.
Old 01-01-2009, 09:53 AM
Tony Shepherd's Avatar
Actually Taner has a sheet metal intake.
To the OP.......if you goal is only 450rwhp N/A stick with a stock intake. Get it cut, ported, welded......etc and you will be fine. If your goal is 500+rwhp N/A and you plan on spinnning the motor to 7500-8000 rpms the single plane or sheet metal is the better choice.
Old 01-01-2009, 11:30 AM
GIZMO's Avatar
If there was a cast open plane 4150 intake available, how many of you would actually buy one? What would you pay? I import a bunch of castings and something like this wouldn't be that hard to do.
Old 01-01-2009, 11:47 AM
joelster's Avatar
If it had the LT1 bolt pattern and EFI bungs already in it, it would be worth about 450-500 bucks easy. People could either run a 4150 style TB or get a custom elbow and run the stock TB.
Old 01-01-2009, 12:52 PM
F3RR3T's Avatar
No they haven't.
im not going to argue with you. it not worth the wear and tear on my finger tips.
Old 01-01-2009, 01:37 PM
96lt1m6's Avatar
thanks Tony i did not know Taner changed,still does not eliminate the fact that he was well in the 10s n/a when he was the BMR feature car.
