any products out there to protect sparkplug wires?
Old 01-17-2009, 01:36 PM
oifish's Avatar
Default any products out there to protect sparkplug wires?
every since I installed my LT headers on my bastard LT1 I have been a little paranoid that my sparkplug wires may melt and cause problems. Is there any products out there that I can buy to slip over them to give protection?
I have used zip ties and while it kind of worked I want to make sure they are safe. I have also tried thermal tape but the tape doesn't stick for more than a week of normal driving.
I was wondering if there was anything like these http://cableorganizer.com/wire-loom/colored.html but protect against heat?
any advice on some products?
thanks
Old 01-17-2009, 01:51 PM
skanitz1's Avatar
I found these... http://www.partsamerica.com/ProductL...Category=3638I
Old 01-17-2009, 02:33 PM
ss.slp.ls1's Avatar
I know just how you feel man, its a pain to change the wires. I too was paranoid, so I bought these:
http://cgi.ebay.com/Accel-170081-Sle...QQcmdZViewItem
They work great so far, I use them with my duralast wires and Pacesetter headers. Some of the wires are close, but with these, they should live a long time.
Old 01-17-2009, 02:38 PM
Jditlfm's Avatar
Thunder racing sells fire sleeves. I use the Taylor ones that are rated to 1200 degrees.
http://thunderracing.com/catalog/?ac...vid=4&pcid=198
z28rob18's Avatar
i have been through 3 sets of wires after my header install. it pisses me off the one time one burnt on the way to the track and i ran it 3 times thinkin that somethin was really wrong and it was a damn burnt wire and its the same 2 and i cant fix it
Old 01-17-2009, 04:04 PM
oifish's Avatar
awesome those all look like good things to use ill check these out and see how they work, ill probably get those accel boots, and 'Cool-tube' protectors
thanks all
Old 01-17-2009, 04:21 PM
LSWHO's Avatar
I need to get me some, I just lost my first wire within a week.... luckily it happened 500 ft. from my brothers house on the way to the track instead of a little bit later... I limped it back.
Old 01-17-2009, 05:18 PM
Formula350's Avatar
There's lots of stuff, from the common factory braided wire sleeves, to braided metal sleeves, sheet metal boot covers. Then you get into the higher dollar stuff (braided metal may be up there) like the woven fiber glass and I wouldn't doubt there being woven carbon fiber sleeves either.
These are good deals I think, for a bulk buy (unsure how much one would need for full length of the wire, unless you only want to do partials)
http://motors.shop.ebay.com/merchant...dkw=&_osacat=0
EDIT: Speaking of which, if anyone knows where to get that standard black braided sleeves (I think they're higher heat resistant nylon, as they can get rock hard when over-heated like plastic) in different sizes, if you could PM with a location that'd be awesome I'm looking to use it on an non-automotive project, but I don't need really big ID, 1/4" would be the biggest.
Old 01-17-2009, 09:15 PM
I8ASaleen's Avatar
DEI protect-a-boots. Get the ones for 90* boots and never replace burnt plug wires again.
Quick Reply: any products out there to protect sparkplug wires?
