Stock intake manifold
I know the stock throttle body bore is 48mm but what is the bore on the intake manifold ? I've seached and found a site saying 52mm and a site saying 54mm . I'm just curious and was considering a 52mm throttle body if that was the same size as the manifold .
Well, there wasn't a 54mm till someone ported a stocker to it, so most sites will probably say 52mm because that's the biggest aftermarket TB that'll fit on a stock intake. So I'm going to say that it's actually a 54mm opening on the intake itself. Otherwise, why even make a 54mm TB? Why not go between 52 and 58, and make a 55mm?
Thats wierd that there were 52 and 54 mm manifolds . I don't really "need" a larger throttle body I just thought it might help out a little being the same size as the bore on the manifold .
Thats a pretty big margin of error lol . I'll probably just go with a 52mm tb. Probably the professional products one . I seen them for about 200 and I know its not necessary being lightly modded but it seems that if that would match up to the manifold pretty closely it might help out a little with air flow over the stock one .
