how much can my motor take?
my mods r in sig. i just bought a 75 shot and wondering if my bottom end will be safe. what do u guys think? and what is the biggest shot of spray i can put on my car without hurting ne thing?
A local shop owner told me 125 wet no problem on a stock bottom end. Told me he ran his LT on that setup forever. Car had over 200k when he tore it down. And it wasnt broke, he just went in a different direction with the build.
im also concidering the spray route, my car runs great but the body needs paint, the dash is cracked, yadda, yadda. however i dont know if i should fix that stuff or through a mod to it (nitrous) right now i have a cold air, air foil, super comp headers, full exhaust, shift kit, chip, and egr and ac delete. if i put a 75 or 100 shot what am i looking at and will a 100 shot break the tires loose if i spray after it shifts into second
I too agree about 150 and under on the stock bottom end...but if you use the search there are tons of threads about it. I also believe it is in the stickies in the nitrous forum. Good luck and happy spraying!
D
D
I'm spraying 100 shot for the 1st. time on mine, its not enough LOL, i'll be stepping up to a 125, then 150 max, but i'll mostly stay on the 125 shot, just make sure you get all the safety stuff & a good fuel pump & have the PCM tuned for the nitrous , 100 shot is cool at 1st., but it gets old quick, this o'le motor just laughs at it , even at 160K, so don't sweat it, just spray it!!
