Low coolent light? spray?
just hooked up my wet kit and after and when i spraying my low coolent light comes on...im not leaking any and when i turn the car off and back on it goes off.
EDIT: Also how do i know if fuel is passing thourgh the fuel line that is connected from the fuel rail behind the intake manifold to the fuel solenoid for the spray.
The schrader valve is the little valve with the little pin that you have to push in to let fuel out. Just like you have to push in the pin to let air out of a tire. You have to physically remove it (I don't knwo how though, it might require a special tool, try a search) and then it will provide a constant supply of fuel to your fuel solenoid. DON'T SPRAY until you fix that, you won't have any fuel to go with the N2O and you'll detonate and ruin your engine.
Ok, it seems that you can get a schrader valve removal tool from Autozone.
If you do it with the car off, depress the pin first, it will depressurize the rail. Wrap a rag around it first to catch the gas coming out. The remove the schrader valve. Reconnect the line, then you should be good to go.
