LT1 heads... will any year work on my '96?
Old 02-17-2009, 09:12 AM
impaled's Avatar
Default LT1 heads... will any year work on my '96?
i am looking for a set of LT1 heads to port and polish with my instructor, and found a set of 93 heads. will those heads work fine or do i need a '96 set or heads?
thanks.
Old 02-17-2009, 09:17 AM
fergymoto's Avatar
They will work.
Old 02-17-2009, 09:36 AM
chevy42083's Avatar
I've always wondered the same thing.
I have '93 heads with a 94/95 intake. I've seen some places that claim '93 head ports were shaped slightly different. .... but it's all a crap shoot as to whether the ports on mine were matched or not. Never had them off to even take a look.
Old 02-17-2009, 09:45 AM
impaled's Avatar
as far as inspection goes, i obviously cant magnaflux them (aluminum), dont want to pay to get them pressure checked, which leads me to die penetrant to look for cracks. so where could i get some die pennetrant?
i dont want to blow $150-200 for heads that are cracked
if they are just a little warped my instructor will help me mill them as long as it doesnt send my compression beyond 93 octane.
ss.slp.ls1's Avatar
Try to find a set of heads with casting number 10207643 or 10128374, they have more meat on them and are more desirable for porting.
Old 02-17-2009, 10:05 AM
Hardtop94's Avatar
i have the stockers off my 94 z28 i started porting one but didnt finish and the other is untouched, the come complete and have no cracks, i pulled them and upgraded, pm if your interested but otherwise any year lt1 head will fit.
Old 02-18-2009, 08:50 AM
impaled's Avatar
thanks for the good casting numbers.
Old 02-18-2009, 09:09 AM
$O$OE's Avatar
are the heads i bought of you any of those listed above?
I always wondered about those heads if they had more meat on them, was never sure though.
Old 02-18-2009, 09:57 AM
impaled's Avatar
what is a fair price for a set of unworked LT1 heads? just to make sure i dont pay too much...
Old 02-18-2009, 10:09 AM
$O$OE's Avatar
I have no idea, im guessing around no more than 100
Old 02-18-2009, 10:10 AM
whammer33024's Avatar
if you found them for 100 bucks then you're doing REALLY well...175-200 is usually what they go for...trust me...i'm looking right now, lol
Old 02-18-2009, 10:22 AM
ss.slp.ls1's Avatar
Not sure. You have to look at them.
Last time I bought head, I picked up a set for 300 about 3 years ago.
I'd try to get them for 200 or less.
Old 02-18-2009, 10:43 AM
$O$OE's Avatar
yeah ill check them out in march or ill have my brother check them out
Old 02-18-2009, 10:53 AM
Puck's Avatar
93 heads should be the 374 castings.
Like stated, they will all work on any LT1. Also, you would have to mill stock heads a LOT to get out of pump gas range with the stock block and pisons so you shouldn't worry about that either .
Old 02-20-2009, 08:59 AM
impaled's Avatar
i found a set of 374 heads for $150 and am going to pick them up in a day or two.
as far as porting goes, what do you think i will be able to put in as far as valve size?
Old 02-20-2009, 09:06 AM
ss.slp.ls1's Avatar
I don't think you want to go anything bigger that 2.02"/1.6" to avoid valve shrouding. But I'd double check on that.
Old 02-20-2009, 09:17 AM
impaled's Avatar
the AI compition port has 2.000 and 1.560" valves, so that would probably be sufficient. the 1.6" might be pushing it at that rate. i know AI has put alot of thought and testing on their LT1 heads.
Old 02-20-2009, 11:46 AM
1badzee's Avatar
Damn, that better have been some good head if it cost you that much!
Old 02-20-2009, 11:50 AM
ss.slp.ls1's Avatar
LOL. For that kind of money, I could get what ever I want.
Old 02-20-2009, 11:58 AM
Hardtop94's Avatar
trying to dump my stockers for 100 bucks seen them for more but dont know why you would pay more, i found a set of edelbrocks on craigslist complete for 500 thats a deal but they wont work for my setup, going to get a set of the patriot lt1 heads they look like a great buy with all they have
Quick Reply: LT1 heads... will any year work on my '96?
