car shakes when i hit 90
well im not sure what could be causing this but when i hit about 90 mph in 5th gear the car starts to vibrate and slightly shake i dont speed very much but every so often ill open her up on an open highway and once i hit about 90 i feel these vibrations and it doesnt sound good any input on what may be causing this...thanks
thanks guys...if i were to replace my stock drive shaft with an aluminum ls1 driveshaft...will there be any modifications i need to make so that i can replace it or will it bolt right up? and is it something that i could do on an afternoon off in my driveway haha just curious cuz that would be my plan....again thanks!
Mine did the same thing around 85 mph and up even when you let off the gas it vibrated untill it got under 85 mph....
I went and got my stock drive shaft balanced and he put in a new unaversal joint and 90% the vibration went away :-) well worth the $50.
I know my tires need to be balanced because I seen one of the wieghts gone and another moved so time for me to get them balanced
well thanks everyone...i will either get a brand new driveshaft or i will take it to a very reputable shop by my house and have them balance it...ill also have my tires checked out just to be safe...again thanks for all the comments
