93 z Camaros
Old 02-21-2009, 11:29 AM
madmike9396's Avatar
Default 93 z Camaros
Is all 93 z camaros geared 323 from the factory ? Thanks to anyone with info
Old 02-21-2009, 11:31 AM
moderate Z28's Avatar
No some come with 2.73. Check the codes on your glovebox for your gear ratio.
Old 02-21-2009, 11:34 AM
what is the code for 323s
Old 02-21-2009, 12:02 PM
fergymoto's Avatar
GU5 is for 3.23s.
Old 02-21-2009, 06:31 PM
93_z28's Avatar
and i just read in another thread that GU3 is for 2.73
Old 02-21-2009, 08:04 PM
ok thanks guys
Old 02-21-2009, 08:43 PM
$O$OE's Avatar
those codes are called RPO codes, u can just Google something like RPO codes for1993 Chevrolet Camaro..etc and some good info will show up
Old 02-21-2009, 09:11 PM
Formula350's Avatar
GU3 is 273, GU5 is 3.23 and GU6 is 3.42 and all will be on your RPO sheet inside your glove box (for 93s).
And if you come across an S10 with GW8/GT5 (not sure which RPO is for S-Series) that's 4.10s and GT4 is 3.73s. Older ones (mid 80s) with H04 have 4.11s. If you feel REALLY crazy, 4.56s are HC4
