Can I reuse my head studs
Hey guys I was wondering if I can keep my current head studs when changing head gasket out. Money is tight at the moment put if needed I can do a budget. So what would you recommend? I am getting new head bolts but to I need to get new studs?
If you are already getting bolts, why are you asking about studs? You don't use both. Plus, you could reuse the studs and not buy anything. Studs are problematic to seal, though. Curious as to why you are having to change the head gasket(s).
