hey guys how are 28" tires with a 3.23 gear cam only car
Old 02-28-2009, 10:04 AM
robsquikz28's Avatar
Default hey guys how are 28" tires with a 3.23 gear cam only car
Old 02-28-2009, 10:07 AM
RamAir95TA's Avatar
28" tires with a 3.23 gear will act more like 3.00" gears on a 26" tire. You're effectively reducing your gear ratio.
Old 02-28-2009, 10:08 AM
z28rob18's Avatar
theres a calculator for this in the drag section and depending on the power range of the cam they could be too big if 6200 is the end of the power band the spinning more then that would be where the power starts to drop. but with nitrous it could keep pulling
Old 02-28-2009, 10:51 AM
Z-RATED94's Avatar
What stall rating is his converter? If it's stock, he would need a higher rear gear. More info please.
Old 02-28-2009, 11:04 AM
PewterScreaminMach's Avatar
28" tires are going to be pretty tall for a 3.23 car.
Old 02-28-2009, 11:30 AM
fergymoto's Avatar
4.10s would be more appropriate with a 28" tire for a car at that power level. 3.23 is going to be way undergeared.
Old 02-28-2009, 11:44 AM
LS1 SPEED's Avatar
28" can work if stalled properly
I run a 3.42, 28" & SS4000 on my dad's LS1 car and it works well on and off spray.
1.52 NA
1.44 N20
Old 02-28-2009, 01:08 PM
well it has a 3600 stall
Old 02-28-2009, 09:24 PM
SHDY 5.7's Avatar
I had this same debate once. I also knew of a couple guys claiming 75 and 100hp but it was more like 150 and 200.
Old 02-28-2009, 10:21 PM
anyone whats better the 26 or 28 tire
Old 03-01-2009, 03:31 AM
fergymoto's Avatar
26 if you are sticking with 3.23s.
Old 03-01-2009, 07:48 AM
LS1 SPEED's Avatar
yes..as you sit it would most likely be best.
Old 03-01-2009, 07:49 AM
LS1 SPEED's Avatar
yes it would most likely be best, but all that can be done is testing to be sure
Old 03-01-2009, 10:59 AM
SHDY 5.7's Avatar
Nothing tells the story better then the ole 1320!
Old 03-01-2009, 11:00 AM
7.0 camaro's Avatar
i had a 3rd gen with a 3.73 gear. and a 28'' tire. i was cutting 1.50's 60fts. i switched to a 3.42 gear and a 26''. everyone was like huh??? why would you do that. it still cut 1.50's 60fts and was more streetable. if you got enough tq a high gear and a short tire are the way to go. but if you dont have power or tq then a higher gear and maybe even a smaller tire. i would go with 26's no matter what.
Old 03-01-2009, 04:24 PM
thats what i thought 26" tire....now i can post this over to the other site and blow him up....damn know it alls....thanks all
Old 03-01-2009, 07:09 PM
fergymoto's Avatar
Just cause he knows everything doesn't mean he knows anything
Quick Reply: hey guys how are 28" tires with a 3.23 gear cam only car
