Sluggish at low rpms <2500
Old 03-04-2009, 07:04 PM
Silver2000WS-6's Avatar
Default Sluggish at low rpms <2500
Hey guys my car is acting real sluggish at rpms less than 2500. It is ok for daily driving but when you hammer down it doesn't seem to accelerate like it should. I have also noticed it cutting out "more like it stumbling" at about 2500rpms for a second or two. This has happened twice in the last couple hundred miles. I am looking for ideas for what might be going on. The only mods are a recent opti spark, plugs/wires, cold air, and headers. I am not sure if this is it but it was not tuned after the headers. Oh yeah even after it is warm it tends to idle around 1000rpms.
Thanks, Chase
Old 03-04-2009, 07:07 PM
94CamaroZ28SS's Avatar
It might be your Throttle Position Sensor is bad causing the High Idle!
Give more info on the car? what size headers?
Old 03-04-2009, 07:10 PM
The headers are pacesetter long tubes. I think they are 1 3/4 Maybe? lol I guess the tps would be a good place to start.
Old 03-04-2009, 07:24 PM
13lu91rS's Avatar
your tach may be off, becuase my idle says its at a 1000 and when i hook a scanner up it reads about 750-780. my car feels sluggish to about 2k also and my mods are in my sig
Old 03-05-2009, 05:49 PM
Yeah I do need to hook it up to a scanner. Maybe that is why it appears to ideal high.
Old 03-05-2009, 09:30 PM
How does the Shifts Feel? does the tranny shift like its supposed to or does it hold the gear for hella long? What about throttle response?
Old 03-06-2009, 03:12 AM
Its a M6 but the throttle response does seem a little slow.
Old 03-06-2009, 10:59 AM
I would say its your tps.
Old 03-07-2009, 12:56 AM
busdude's Avatar
We have the same mods, and Im having this same problem. On my post I was led more of the direction of the igniton system. but the TPS dosnt seem a bad idea. Except mine has had tendency when let off the gas to idle at 1500 then followed by droping down to under 1k
Old 03-07-2009, 12:59 AM
IMgettingLS1's Avatar
mine has done it every time when it has been sitting. but if i drive it everyday it ist too often, ive always fiured it could be the tune
Old 03-07-2009, 08:41 AM
myltwon's Avatar
I'd lean towards vacuum leak
Quick Reply: Sluggish at low rpms <2500
