Really NOOB question about TB bypass
Hey ppl I decided to do the TB by-pass. My old coolant line on the LH side on the steam pipe was so stuck on I had to tear it in half and then I removed both sides. COULD I take the coolant line for the RH and just connect it to the steam pipe. My gut says that it should be fine but I wanted to check with you guys and your opinions. i bought extra coolant line hoses in case that I was mistaken and I had to connect both hoses and use the adaptor that I bought for this bypass.
Thanks,
Devin M
Thanks,
Devin M
I figured it out I zip tied it out of the way and started it and no leaks, on the first two starts the car seemed to start up and then just for one sec the idle was diff. Is this a problem??
