Finishing up the 396, couple ???
I'm about ready to finish up my 396 project but I had some questions. First of there's a guy I know who is selling me a 4.3 baby LT1, I a wondering are pretty much all the bolts and external parts the same as the regular LT1? I needed some bolts from it, for example rear main seal bolts, bolts to intake mani, and maybe the ones to the pulleys. Next question is, do I have to angle torque the heads? and is it difficult? It said to angle torque them in the LT1/LT4 rebuild book. Thanks in advance
Torque-angle torquing is a more acurate method of fastening anything because it uses bolt stretch, rather than torque alone to reach the required clamping force. For a 396, I wouldn't use anything short of ARP head studs though.
Yes, besides the displacement, it is identical.
Torque-angle torquing is a more acurate method of fasting anything because it uses bolt stretch, rather than torque alone to reach the required clamping force. For a 396, I wouldn't use anything short of ARP head studs though.
ARP head bolts would work fine. IMO, studs are too much of a hassle when bolts will work just the same. If you use ARP head bolts, tighten them in sequence in 3 passes: 1st - 20lbs, 2nd - 45lbs, 3rd - 70lbs.
It should be noted that this method is only to be used with torque-to-yield bolts (i.e., stock replacement).
I have used both ARP bolts and head studs. Either one is better than stock. But from what I have read, the studs are better than the bolts for a more uniform clamping of the head to the block.
Village Troll
My builder who did my 396 short block recommended ARP head bolts instead of studs. Their claim is studs will cause more core shift than bolts. I followed their advice, have bolts and all has been well. Granted I am not running any crazy cylinder pressure at this time. Just Cometic gaskets and all is well for over a year and counting.
You think felpro 1074's will hold up to a 200 shot nitrous, Or perhaps a little more?
