weird startup question...
so i posted a couple weeks ago about having a sputtering startup...
so i would prime the engine twice and it would start up fine, but if i dont prime it or sometimes only prime it once it sputters or something...im thinking its either the fuel pump regulator or the fuel pump...does anyone know if this is a specific problem for either or if its something else?
havent had a chance to yet, i was hoping maybe they were symptoms of something common...what would the pressures be with key on engine off and engine running?
Mine did the slow die-off and would look okay at idle, but would eventually shut off while driving.
all the pressures are fine, i think its actually the starter. when i let the car prime i hear something clanking under the car likes it almost the starter engaging...is this possible? it sounds like the starter gear is getting stripped or something on the flexplate
