Stroker or not ????
Old 04-01-2009, 11:25 PM
RaM AiR 97's Avatar
Default Stroker or not ????
ok guys i finally gathered the parts to do a cam swap on the formula and then the F_ing car starts to give out on cyl # 7. i really dont want to spend the money on a stroker but if repairing that will cost me around the same ball park i might as well. what do u guys recommend and if so what did it cost u guys.
Old 04-01-2009, 11:47 PM
96lt1m6's Avatar
you don't have to build a stroker if you dont want to.
did you do a compression test?
If your stock crank is in bad shape then i would consider doing a stroker since you will be buying the replacement parts you may aswell get more TQ
Old 04-02-2009, 08:34 PM
ryleag's Avatar
Are you planning on boosting it? Or staying N/A?
Old 04-02-2009, 08:38 PM
trippinholyman's Avatar
stroke 'er, i hardly knew her! 383 all the way
Old 04-05-2009, 08:38 PM
RaM AiR 97's Avatar
I really dont want to spray it. My question is how much would everything come out to i know that many of you here have done strokers or just rebuilt a 350 lt1. I mean including parts and labor so i can freakin start saving and what would you guys recomend
Old 04-05-2009, 08:59 PM
AChotrod's Avatar
It way cheaper to rebuild a stock 355 but if you want a bullet proof bottom end it get pricey
Old 04-05-2009, 09:25 PM
RamAir95TA's Avatar
My 383 short block cost me around $3900 in parts and machinework. After heads, valvetrain, etc., I'm up to around 7 or 8k...don't really remember exactly anymore.
Quick Reply: Stroker or not ????
