header hitting k-member
Old 04-08-2009, 04:25 PM
iceman15's Avatar
Default header hitting k-member
Have any of you guys ever had a problem with Jet Hot LTs or any header hitting the K-member? Ever since i put these LTs in, one of the primaries hits the K-member.
Ive read that some people have problems with LTs hitting the excess thin metal on the K member that can be cut off. But mine is hitting the whole K member and its annoying when it rattles/rubs when i drive.
Old 04-08-2009, 04:26 PM
ss.slp.ls1's Avatar
Sounds like your motor mounts have seen better days...
Old 04-08-2009, 04:37 PM
iceman15's Avatar
The thing is that I had replaced my motor mounts when I did the header job. Its really driving me nuts!
Old 04-08-2009, 04:38 PM
ss.slp.ls1's Avatar
Oh, well there goes my theory. Time for some LPP's maybe.
Old 04-08-2009, 04:40 PM
iceman15's Avatar
damn man I hate to spend more money on another set of LT's
Old 04-08-2009, 05:34 PM
litch2004's Avatar
mine does the same thing. I have hooker headers and it hits on my driver side. It really sucks since i had mine jethot coated like yours and it has rubbed it off there now. The only option that i have found is getting a tubular k-member
Old 04-08-2009, 05:43 PM
AChotrod's Avatar
My LPPs hit the k-member on the PS so we notched it out, I will buy a tubular K-member to truly fix it soon
Old 04-08-2009, 05:55 PM
DopdBrd's Avatar
Same problem here. LPP's are hitting the k member. Gonna take a grinder with a cutout wheel to it tonight and solve the problem until a BMR Tubular unit can find its way underneath it.
Old 04-08-2009, 06:43 PM
iceman15's Avatar
Yea notching it out seems like the only valid way to fix it unless you get a tubular k member. Will notching it out weaken the stock k member at all?
Old 04-08-2009, 09:50 PM
AChotrod's Avatar
NA. Im not worried about it, seem this is a problem with all brands hit or miss. Cool part is its cheaper for a K-member than new headers and an excuse to buy one!
Old 04-09-2009, 06:59 AM
creepingdeath94's Avatar
Yup...I am currently in the process of fitting my Ebay, LPP copy LTs and it hit in a bunch of spots: I had to remove the remote oil cooler on the oil filter, cut out not only the thin metal ledge, but also a round spot in the K-member in 2 spots for two of the tubes to clear the frame. It's not a lot, but just enough to make installation drag on into today when I was anticipating them being done yesterday. I was actually just about to ask if this was a common problem or if I had a defect in the set I bought/geometry was off or something. Obviously it has arose before :-(
Old 04-09-2009, 09:18 AM
xx_ED_xx's Avatar
Nope it seems not so easy for someone to make a quality product.
Old 04-09-2009, 09:31 AM
Elliott's94Z's Avatar
My LPP's cleared the K-Member just fine. Seemed like some of you guys had to really do some modifications to get them to fit. Guess other then having to remove the oil cooler I got lucky. To the OP, you will have to grind it down a bit it sounds like.
Old 04-09-2009, 10:42 AM
kinglt-1's Avatar
Never herd of pacesetter LT's hittin the k member either. Atleast mine don't!
Old 04-09-2009, 10:50 AM
LaVy's Avatar
x2 I went with pacesetters because I knew from other lt1 owners in my area that they fit great.
Old 04-09-2009, 01:17 PM
iceman15's Avatar
Yea i guess every car is different as far was fitment issues. Looks like i got to get the dremel down there and get to work on the k member.
Old 04-09-2009, 01:51 PM
AChotrod's Avatar
LOL! Search it. Lot of PS LTs have fittment problems or they blow holes in them or rust away....
Old 04-09-2009, 01:58 PM
litch2004's Avatar
Mine are hooker super comp jethot coated and only one of my primaries hit on the drivers side but i think mine are hitting because the engine mounts have seen better days
Old 04-09-2009, 01:59 PM
ss.slp.ls1's Avatar
Really, that's news to me. Mine fit great.
Old 04-09-2009, 09:41 PM
Irocss85's Avatar
my jet hots hit on the pass. side. had to notch it. it will not hurt the frame. just cut to lines and hammer the middle into the kmember. done. then install the header. the factory Kmember is exremely strong. dont even worry bout it.
Ive installed quite a few sets of headers, and there all a bit diff. from car to car, header to header. (Im talking same name brand header to header). matter of fact, I could get you a pic of mine since the eng/Kmember is still out of the car in the garage.
Quick Reply: header hitting k-member
