lt1's are so gay
Old 04-14-2009, 01:54 PM
93TAJ.C.'s Avatar
Default lt1's are so gay
Ok so on top of having a nasy hesitation and backfireing problem at low rpm's, the car just dies while driving but will start right back up. Is this an icm issue?
Old 04-14-2009, 02:00 PM
dkishton1486's Avatar
Some more info aboutthe car would help....miles,year,when last tune up was done
Old 04-14-2009, 02:16 PM
ss.slp.ls1's Avatar
Back firing is usually caused by an ignition problem I'd check the plugs, wires, coil, opti, and ICM, replacing parts in that order.
Old 04-14-2009, 02:34 PM
explicit.muscle's Avatar
Sounds like what mine is doing right now. I have 2 burnt plug wires. I need to put on my Thunder Racing OTVC wire kit, but no time!!!!
Old 04-14-2009, 02:37 PM
C5042081's Avatar
if all these things check out ok move on and check the fuel pressure
Old 04-14-2009, 02:38 PM
RSbeast's Avatar
Mine did that last year after sitting for an extended period of time over winter outside. Ended up having condensation or something in the opti. Took the breather lines off and parked it in a dry garage, finally cleared up and ran normal.
Old 04-14-2009, 02:56 PM
ulakovic22's Avatar
So a 93 Trans Am, any modificatins done? Any codes being thrown?
Old 04-14-2009, 04:05 PM
93TAJ.C.'s Avatar
yes, its a 1993 trans am m6 gt. I just had the engine out and used new msd wires, ngk tr6 plugs, and msd cap and rotor. The coil and icm were kept and had no problems untill now that i got the engine back in. The car is backfiring and running rough but doesent seem to be related to the car just dying. I t has had the opti like symptoms for a while now but just started dying today.
Old 04-14-2009, 04:11 PM
Sharpe's Avatar
And, the O2's, right? On an LS1, the front O2's can cause similar problems. Forget about the LT's. I had every problem you can have with my '94 Z. Then, I learned that LT's are, indeed, "gay" and moved up.
Old 04-14-2009, 04:18 PM
1994Z28Lt1's Avatar
Why the TR6's? too cold of a plug for a stock setup
I would be checking those plugs out to make sure they aren't fouled or anything
Old 04-14-2009, 04:27 PM
ss.slp.ls1's Avatar
Yes, OP, check your o2's with a scanner. And as someone else stated, check your fuel pressure.
Old 04-14-2009, 07:24 PM
wrd1972's Avatar
LT1 s are gay, huh?
Sorry that your lack of SBC and automotive knowledge is leading to this pithetic conclusion. Your motor probably just hates your frigging guts for being stupid.
Old 04-14-2009, 07:58 PM
1badzee's Avatar
Originally Posted by wrd1972
LT1 s are gay, huh?
x2 The LT1 isn't gay; You are.
Old 04-14-2009, 08:06 PM
wrd1972's Avatar
Please sell your LT1 right now and get a V-tec ***-wagon.
MTBSully's Avatar
your so gay
Old 04-14-2009, 08:16 PM
x3d187's Avatar
LMAO
Old 04-14-2009, 08:21 PM
OnA Fan's Avatar
Mine used to stall and start back up, and than a month later, it wouldn't start back up that easily anymore. New ICM fixed it.
Oh, and LT1's are so gay, I just brought another one home today.
Old 04-14-2009, 08:40 PM
Elliott's94Z's Avatar
LT1 s are gay, huh?
Originally Posted by MTBSully
your so gay
Lmao....I actually have a GAY OL' TIME in mine.
So why did you go with the TR6 plugs? Have you double checked all the wires, plugs etc etc. I had your same problem and it ended up being plug wires...they were new as well.
Old 04-14-2009, 10:01 PM
litch2004's Avatar
i had the same problem about 2 years ago and mine was the ICM
Old 04-15-2009, 09:14 AM
93TAJ.C.'s Avatar
Damn guys. It was just a joke. I dont really think lt1's are gay, if i did i wouldent have pulled the engine, got 2500 bucks worth of:
lt's with 3" ory, svo injectors, cai, rear main seal, pan gasket, valve cover gaskets, timing set and gasket set, madz28 pcm tune, tranny output seal, opti cap and rotor, water pump, ws6 wheels and tires, air foil, plus wires, and poly motor and tranny mounts.
I do know alot about the lt1, and have for years, i just havent been able to afford one untill i had a friend buy one, abuse it, and sell it to me. It went from not running at all, to my daily driver in 2 weeks. I just thought someone may have had the same problem as me and could tell me something i havent thought of yet, I have been over the plugs and wires. At this point im thinking opti, and/or icm.
Quick Reply: lt1's are so gay
