Help! Installing Opti and want to delete AIR
Old 04-24-2009, 07:12 PM
gregrob's Avatar
Default Help! Installing Opti and want to delete AIR
What do I need to delete the AIR pump.
I have it all pulled off and don't want to put it back on...
I have stock headers right now but prob putting my AZSM's on tomorrow.
Thanks!
Old 04-24-2009, 07:46 PM
Badazz 97 TA's Avatar
buy 2 metal caps for the headers. you can buy some from the hardware store. then plug the hole thats in the air intake. thats it
Old 04-25-2009, 12:17 AM
1bad72's Avatar
How much power do you gain from the Air delete?
Old 04-25-2009, 12:22 AM
Bad_tx_Z28's Avatar
AFAIK nothing really. just wieght savings.
Old 04-25-2009, 12:28 AM
juanito's Avatar
and looks cleaner.
Old 04-25-2009, 07:41 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I removed my AIR. It wasn't difficult to do, but I can't really remember everything that had to be removed. I know there was a metal pipe that ran across the front of the motor that I had to cut in order to get it off. If you have emissions headers, there might be some additional connections that have to be blocked off. I was installing race headers, and didn't have to worry about that.
There aren't any power gains associated with removing it, but it does get rid of a little weight, and cleans up the engine bay a little bit.
Old 04-25-2009, 11:11 AM
RamAir95TA's Avatar
93-95 style manifolds require a M22 plug, 96+ require an M18 plug. Most ordinary hardware stores will not carry automotive thread, so you may need to have it special ordered.
Old 05-09-2009, 07:49 PM
R3DLT1's Avatar
Yes agree with everyone above. Im in the process of changing out my opti and talking out the AIR. Buy some vacuum cap your goona need two.
Quick Reply: Help! Installing Opti and want to delete AIR
