View Poll Results: ew Cam Or Heads?
CC 502
0
0%
CC 305
0
0%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
cam selection help
cam selection help
ive been reading the cam/valvetrain selection guide on the site, and ive lowered my choices down to 5.
CC 502-218/224 .528/.537 112lsa w/ 1.6RR's
CC 305-220/230 .544/.544 114lsa w/ 1.6RR's
CC 503-224/230 .537/.544 112lsa w/ 1.6RR's
XFI 466-218/224 .570/.565 113lsa w/ 1.6RR's
GM 846-222/230 .543/.563 112lsa w/ 1.6RR's
LPE 211/219-211/219 .530/.560 112lsa w/ 1.6RR's
any suggestions or recomendations to what will work well with stock heads?Is a tune required for the computer? And what else would do i need to purchase pushrods, rocker-arms, springs and retainers? Does it make sense and is it cheaper to go with new assembled heads? Such as Patriot Performance 2046 heads?(specs below)
Technical Specs:
Combustion Chamber: 58cc
Intake Runner: 195cc
Exhaust Runner: 70cc
Intake Valve: 2.02"
Exhaust Valve: 1.60"
Max. Valve Spring Lift: 0.550"
Spring Pressure Closed: 130 lbs. @ 1.800"
Spring Pressure Open: 45 lbs. @ 1.250"
Retainer Material: steel
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 5-angle
What will have more of a horsepower gain, new heads or a new cam? im thinking it makes more sense to get new heads and then get a new cam later that matches the heads? THANKS ALOT! IM JUST TRYING TO DO SOME RESEARCH BEFORE BLOWING MY CASH!!
Technical Specs:
Intake Valve: 2.02"
Valve Job: 5-angle
Lunati for the win, same lobe design used by one of the more popular "custom grind" cams promoted on this website with proven results. Throttle response is amazing and couldn't be happier overall. Link to dyno vid in sig on stock shortblock/ stock heads.
update: how does this sound?
Patriot Performance is proud to announce their new aluminum190cc LT1 head. We have designed these heads to work well on 350-383 LT applications. The heads were designed to use a stock LT1 intake. Heads come assembled with our famous Patriot Gold .650” hydraulic roller springs, titanium retainers, 2.02”/1.60” stainless valves. bronze guides, viton rubber seals, 3/8” studs, and guide plates.
Sold As Pair
Technical Specs:
Intake Valve: 2.02"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.150"
Retainer Material: Titanium
Valve Job: 5-angle
heres the link https://www.patriot-performance.com/...1&cat=0&page=1
Sold As Pair
Technical Specs:
Intake Valve: 2.02"
Valve Job: 5-angle
that is the biggest emmisions friendly cam they had in the voodoo line 219/227 at .050 advertised 270/278 with a 112 lsa but if you read on the website and the reason I went with Lunati is their ramp speeds. Their lobe design is more aggressive than some other off the shelf cams. You can clearly see it on the lobes that it opens the valve really fast then sets it down a little bit slower but till a pretty steep lobe.
those heads look good on paper but from what I have seen most aftermarket heads (besides AFR they are decent) leave much to be desired right out of the box. They still need to be sent to a reputable machinist to do the porting. Depending on what your goals for the car are you might be better off with ported stock heads. The people who opt for aftermarket heads and then have them ported are making more power than a stock head can flow ie. aftermarket heads have a little bit more material to port out so you can potentially open them up a little but more. By you pointing out a 190cc head than that is not what you are looking for, it seems to me like a daily driver/weekend warrior that you would like to maintain streetability. In that case I would definately say ported stock heads with a lunati or a custom grind (personally I am a fan of lunati) to give you the results you seem to be looking for.
thanks for the great suggestion, a daily driver with ok driveability (i can handle some lope in the cam, not rediculous though)/road warrior is exactly what im aiming for..when you added the lunati cam, what did you have to do with the valvetrain? 1.6 rr's? different pushrods? etc. also, since i live in hawaii, i know theres no good machine shop to port these...any suggestions?
now that youve got me on voodoo, i think this one sounds interesting...
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .535/.550
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2400-6200
Includes: Cam Only
LSA/ICL: 110/106
Includes: Cam Only
As always, I hate to sound like a broken record but Advanced Induction or Loyd Elliot all have a gang of followers, I personally am going to go with Lloyd, he will set you up with the springs and locks than all I would recommend getting a good 1.6 roller and some good pushrods that are the correct length!!! You are also going to need injectors, headers, stall and tune to get the best results/ most reliable set up. I would also suggest a timing set while you are in there and have a look at that opti (normal maintenance)
That last cma sounds great I don't know what your shortblock is like but that is something that you don't need to spin to the moon to get your power out of it, make sure you do your research do it right do it once. There are a lot of supporting mods that can add up to well more than the cost of a cam and some heads!
UPDATE: slowly narrowing down my choices thanks to JB 97ws6TA...heres what im looking at now...
LSA/ICL: 110/106
Includes: Cam Only
Still too radical? also, does lloyd elliot have a website? do you have any expierience with tuners? thanks for all the info
LSA/ICL: 110/106
Includes: Cam Only
so many options...now im looking at the 226/230 .565/.565 111 LSA. - 1900-6200 RPM because of my bottom end...but im still likeing the lunati because of the ramp
how does this combo sound to you...
LT1 LE2 heads consist of :
Manley 2.00/1.56 6000 series valves
PAC 1218 bee hive springs (145 lbs seat and 340 lbs open)
Steel retainers and locks
205 cc intake port
milling, cleaning and assembly
flow about 275/190 CFM
assembled and ready to bolt on but substitue the patriot extreme gold springs
with the lunati voodoo
LSA/ICL: 110/106
Includes: Cam Only
with comp pro magnum 1.6 rr's, pro magnum type r hydralic rollers, and a timing set
205 cc intake port
LSA/ICL: 110/106
Includes: Cam Only
