LT1 Backfires After Header Swap
Old 04-28-2009, 09:29 PM
Black94Z28's Avatar
Default LT1 Backfires After Header Swap
Switched from mids to longtubes and got everything hooked back up, running open headers btw, car started right up, ran but every 5-10 seconds the exhaust pops and shoots a flame out of the headers. I started it once, did it a couple times, shut the car off, checked everything, started it again, ran it for about a minute, no pops or backfires, shut it off, then i started it back up again and it started backfiring again.
I ran the car without the cold air intake and the air temp sensor wasnt plugged in but the MAF was hooked up. Also didnt have the O2 sensors hooked up since the headers didnt come drilled for them. Was thinking that would have been it, but i cant imagine the car going into closed loop immediatly since O2s only read in close loop right?
Any ideas?
Old 04-29-2009, 11:14 AM
ss.slp.ls1's Avatar
With open headers, (no tune?) and no o2's, it's likely that you are running really rich, hence the backfires out the exhaust. To be certain though, I'd check to see that you have the wires hooked up correctly and no wires are touching or arcing to the headers.
Old 04-29-2009, 11:17 AM
harner's Avatar
Did you hook the Opti up correctly?
Old 04-29-2009, 08:36 PM
Black94Z28's Avatar
Didnt touch the opti, im pretty sure the wires are run right, but have mixed them up before, so ill double check.
I dont have a tune, but do i need one for just bolt ons right now?
Old 04-29-2009, 08:42 PM
marc97taws6's Avatar
For open headers, yes you will probably need a tune..
I'd just do a tune anyway with headers over the factory tune.. should notice some gains and should run much better
Old 05-13-2009, 08:11 PM
Black94Z28's Avatar
haha im a retard, I mixed up the plug wires for cylinder 6 and 8, runs fine now lol
Old 05-13-2009, 08:13 PM
blake110106's Avatar
lol When I bought my car the previous owners did that and then trader the car in cause it was missing lol got the car cheap!
Old 05-13-2009, 08:19 PM
ss.slp.ls1's Avatar
Happens all the time. Not to me though.
Old 05-13-2009, 08:23 PM
Black94Z28's Avatar
of course cause ss.slp.ls1 is always perfect 100 percent of the time
Old 05-14-2009, 11:38 AM
ss.slp.ls1's Avatar
LOL. While I never mixed up my plug wires, I once forgot to plug the opti harness back into the engine harness. Scared me for about 10 seconds until I looked under the hood.
Quick Reply: LT1 Backfires After Header Swap
