Still interested in single plane conversion!
What kind of info? It is pretty straight forward, and if your car is built up enough to need one already then you should have no problem doing the swap. Use your imagination, there are plenty of ways to go about it and not only one is the "right" way.
Tons of info floating around this and other LTx forums, some good reading is out there.
I guess my final decision will be based around the results we see on the HSR conversion, If they are any good it may just be better for me to go that direction.
James
Right, there is tons of info floating around, unfortunately you have to jump through all the right hoops to gather it all, anyway I thought the job from 860 only allowed the use of a monoblade, I really would like to keep my 58.
James
James
Thanks bro,
James
