Anyone that has done the fuel line relocation mod come in
Old 05-04-2009, 08:15 PM
litch2004's Avatar
Default Anyone that has done the fuel line relocation mod come in
So i just decided to relocate my fuel lines and didnt want to make a loop in the wheel well considering i dont have the plastic pieces. I also didnt want to cut and fit my lines just incase of that error and i would have to buy new ones.
So what i did is i relocated mine through the wiper cowl since there was already a gap between the cowl and the body. Then looped it over the side of the cowl and then behind the brake booster and then to where the fuel rail is.
Has anyone done it this way and if so has there been any problems doing it this way?
Old 05-04-2009, 08:16 PM
litch2004's Avatar
if anyone needs pics to know what i am describing let me know and i will post them
Old 05-04-2009, 08:28 PM
gregrob's Avatar
post them
Old 05-04-2009, 08:31 PM
litch2004's Avatar
ok give me a minute.
Old 05-04-2009, 08:40 PM
Black94Z28's Avatar
yeah, i was looking at doing that to mine since Im not running wheel well plastic, but i was wondering if there is any disadvantage to this?
Old 05-04-2009, 08:44 PM
litch2004's Avatar
not sure but it didnt put any drastic bends in mine and it doesnt have any loops in it and it almost puts it in the perfect place to hook up the fuel lines from what i can tell. The engine is in pieces right now.
Old 05-04-2009, 08:52 PM
litch2004's Avatar
this was when i first put the lines through
Then i put the plastic loom back over the fuel lines and pulled it through. The other line is the evap line which i will be no longer using. I just havent pulled it out yet.
Old 05-04-2009, 08:55 PM
litch2004's Avatar
the only thing that i see that i will have to do is trim the cowl cover to allow the fuel lines to go there.
Old 05-04-2009, 09:09 PM
gregrob's Avatar
I like it.
You may need to add a little length to them, and I would wrap them at any juncture where they may touch/chafe on the cowl. Or use a neoprene cable clamp secured by a self tapper to route it where you want and also prevent it from moving around / chafing.
Should work though. Might have to try it this way when I do mine. I will be tidying up the engine bay quite a bit while the engine is out.
Old 05-04-2009, 09:12 PM
litch2004's Avatar
this just started as a cap and rotor replacement and decided to do a cam and valvetrain upgrade. then head gaskets, appearance modifications and so on. I also relocated the wiring harness that was on the passenger side wheel shock tower as well as relocating the hood latch cable. It looks 100X better than it did from the factory
Old 05-04-2009, 09:17 PM
gregrob's Avatar
Mine will be a header/cam swap/heads n intake/clean up engine bay/install ls1 style intake/ yeah... lol
I know how it goes.
Post some pics of the whole engine bay.
Old 05-04-2009, 09:28 PM
James Montigny's Avatar
Can you still pass tech with lines run like that?
Old 05-04-2009, 09:31 PM
litch2004's Avatar
im not sure. that is why i am asking. im not sure on the requirements for this. all i have heard is that they can touch the firewall. and mine arent touching. what else is a requirement.
Old 05-04-2009, 09:35 PM
litch2004's Avatar
My car has a LS1 front end conversion and also a air intake converion. There are also pics up on my photobucket about how i did my alt relocation to where the a/c compressor used to be located. http://s687.photobucket.com/albums/vv233/litch2004png/
Old 05-04-2009, 09:37 PM
litch2004's Avatar
and that loop of wires sitting on the passenger side shock tower is for my MSD 6AL. The wires are normally attached to the shock tower brace but i had to remove all of that to do my cam swap.
MTBSully's Avatar
i spent about 3hrs today trying to relocate my fuel lines today the "traditional" way (behind the brake booster), but i could not seem to get the lines to sit in a way that would not kink them when connected to the fuel rail. The length is fine, i just cant seem to get the angle. Any suggestions? Thanks guys
Old 05-04-2009, 09:38 PM
gregrob's Avatar
that does look a lot cleaner.
Old 05-04-2009, 09:39 PM
litch2004's Avatar
i also think before i put it back on the road i am going to be removing ABS. that thing is a big eye sore when you open up the hood and see everything else relocated and then there is a big manifold sitting there in the middle of no where.
Old 05-04-2009, 09:42 PM
litch2004's Avatar
I'm not sure since i didn't do it that way. The only thing on mine is the connectors are upside down on mine. But if you do a search on it, since the search is now working right, there are plenty of right up on this mod in which i know they go into great detail on this.
Old 05-04-2009, 09:43 PM
litch2004's Avatar
and mine also go behind the brake booster i just didnt drill a hole to push them through i just went through the gap that was between the cab and cowl.
Quick Reply: Anyone that has done the fuel line relocation mod come in
