Help i cant see!
Old 05-13-2009, 10:23 AM
RED PUNISHER Z's Avatar
Exclamation Help i cant see!
i bought a 95 camaro z28 and the thing is my gage lights and dash lights don't work i took the dash a part thinking its a cut wire some where back there and i found nothing i have chaged all the fues what can it be...what do i look for to fix it can some one help i cant see nothing at night the only lights that come on are the check lights in the gage cluster when i turn on the car....can it be the light switch? it turns on the head light but not the dash lights
Old 05-13-2009, 10:28 AM
porksoda's Avatar
What fuses did you change? I kow the "Courtesy" fuse will cause your cluster to not light up.
Old 05-13-2009, 10:45 AM
i chaged all the one on the side of the car and the ones under the hood...where is the Courtesy fuse at?
Old 05-13-2009, 11:41 AM
ss.slp.ls1's Avatar
In the little panel on the side of the car. I believe the tail light fuse can cause your gauge lights to not work either. Sounds like an odd issue.
Old 05-13-2009, 11:45 AM
trippinholyman's Avatar
gremlins!
Old 05-15-2009, 10:36 AM
so can some one tell me how to fix it if i changed the all of the fues ...what do i look for to fix ?
Old 05-15-2009, 10:58 AM
sweetbmxrider's Avatar
your dimmer control isn't off, is it?
Old 05-15-2009, 11:03 AM
ss.slp.ls1's Avatar
^^^LOL, that'd be funny.
Old 05-19-2009, 09:23 AM
no its not off lol ...but can the dimmer control be bad ..so its not leting the lights come on?
Old 05-19-2009, 10:53 AM
check for power at the fuse. if there is power there, the switch isn't the problem. the dark green wire that comes out of the switch is for the instrument cluster. check for power on that wire if the fuse doesn't show power. also, the black wire is the ground. check that the ground is secure and showing ground (just hook a test light up backwards). the ground is shared with the cigarette lighter and the courtesy lights also hook up to it.
Quick Reply: Help i cant see!
