Oil leaks. Be honest,how many of you guys engines dont leak any oil? Please chime in!
Old 05-13-2009, 06:29 PM
moderate Z28's Avatar
Default Oil leaks. Be honest,how many of you guys engines dont leak any oil? Please chime in!
Everyone please reply if you've ever been under your car. I seem to have never had an engine that doesnt leak oil from somewhere and was wondering if there are ANY of you guys engines that doesnt leak oil from somewhere. My LT1 leaks out of the rear main I believe but its so hard to tell where the oil is coming from on these engines. Even if your engine only leaks a small film or a few drops a month I still want to hear about it because that is hard to achieve. If it leaks a quart a week I want to hear about it! So post away! I want to know! Thanks!
Old 05-13-2009, 06:31 PM
Badazz 97 TA's Avatar
Mine is leaking somewhere in the front timing chain cover. I tried fixing it but still leaks. It leaves about 5-6 quater size drops after i turn it off. idling it leaves 1-2 drops. i hate it.
Old 05-13-2009, 06:33 PM
Elliott's94Z's Avatar
I've been fortunate...not a drop once
Old 05-13-2009, 06:34 PM
^ I think thats about the norm for these cars. Mine is leaving 2-3 quarter size drops when I turn it off near where the tranny starts. I have to put cardboard down where I park in the garage. I think its impossible to have an engine that is completely leak free.
Old 05-13-2009, 06:36 PM
Elliot is that sarcasm?
Old 05-13-2009, 06:39 PM
ss.slp.ls1's Avatar
I need to replace my pass side valve cover and front cover. Probably going to bang out all the seals in a weekend.
Old 05-13-2009, 06:42 PM
Honest... Before I gutted my entire motor out I never once had 1 oil drop anywhere. The previous first owner said he has used "Synthetic" from day one. I have as well. Not sure if that has anything to do with it. I would guess to say your rear main is leaking.
nik1703's Avatar
Never a drop.
Old 05-13-2009, 06:44 PM
Wow didnt expect 2 people already. Is there even a film of any gunk or anything on the bottom of the engine?
Old 05-13-2009, 06:46 PM
Very little. My block was in really good shape w/ 76k. Now my Jeep on the other hand pukes oil and differential fluid like it's going out of style and yet still runs like a champ.
Old 05-13-2009, 06:48 PM
strokin93z's Avatar
Zero Leaks!
Only have 250 miles on this one though!
Old 05-13-2009, 06:59 PM
Kaoz's Avatar
Never had leaks, also only had 59k mi sooooo.....
Old 05-13-2009, 07:01 PM
Bad_tx_Z28's Avatar
well, i never leak enough to drop on the ground, but whenever im under the car i see some drips on the oil pan and on the starter, but thats about it.
Old 05-13-2009, 07:07 PM
lt1-xjs's Avatar
Same here.
Old 05-13-2009, 07:09 PM
Puck's Avatar
Mine doesn't now - but that is after changing the oil pan gasket, front timing cover gasket, rear main seal, and intake manifold gasket one after another .
Old 05-13-2009, 07:11 PM
BigZee71's Avatar
My 93 Z with 127K started leaking after I sprayed degreaser onthe underside then powerwashed it off. It was a steady drip drip drip. I droped the motor and trans and Im replacing every gasket on the engine including the rear main seal and front seals, trans pump seal, and pan, tail shaft seal. Hope it works.
Old 05-13-2009, 07:20 PM
RamAir95TA's Avatar
Didn't leak at all, until I pulled the oil pan seal on my first cam install (my bad!).
New motor has no leaks though.
Old 05-13-2009, 07:22 PM
itSSlowZ28's Avatar
i'm leaking somewhere around my timing cover, i think the crank seal. seems to leave a few drops after i cut it off. just replaced a valve cover gasket today and hoping that solves the massive one i had
i looked at a 94 z28 2 days ago with 210k miles on it and it didn't leak a drop, i was amazed
Old 05-13-2009, 07:25 PM
H2O's's Avatar
I have had just about every leak possible!!!!
Old 05-13-2009, 07:41 PM
ss.slp.ls1's Avatar
LOL, that's what happened to my very first LT1. Lost about a quart a week, no joke, leaks and burning oil. RIP old motor...
Quick Reply: Oil leaks. Be honest,how many of you guys engines dont leak any oil? Please chime in!
