TPS? Or OPTI? 02s? Or What?
When i try to crank my car i have to hold the pedel wide open and when it finally cranks its flooding and it will barely run... it has a bad tremble while its trying to idle...
Any thoughts??
Any thoughts??
i tried checking it with a OBD2 scanner but i keeps saying check connection... and i just built 383 and put in it...its been like that since day one i crunk it up..
ok i got timing on TDC... and brand new plugs and wires... i will double check the plug wires tomorrow if it dont rain again... thanx for ya info
See no one would know that seeing your screen name and you not having any information in your sig...
Now for the scanning part, you do need a OBD1 scanner, but you have to do this:
http://shbox.com/1/xraycable.jpg
Yes, if it is a 1995 the car will have an OBD II port and OBD I software. If you have a buddy that has a high end OBD II scanner that does both OBD I and II that will work as well.
