A few pics of my 383 lt1 build
Old 05-19-2009, 11:24 PM
Jose93z28's Avatar
Default A few pics of my 383 lt1 build
Arp studs
[IMG][/IMG]
Keith black forged low com pistons [IMG][/IMG]
1074 felpro head gaskets
Msd cap, rotor, wires, and 1.6 comp cams
[IMG][/IMG]
Edelbrock valve aluminum valve covers, holley 52mm
[IMG][/IMG]
Old 05-19-2009, 11:28 PM
SoxXpupPeT's Avatar
very pretty! i wonder what those dishes out pistons are for
Old 05-20-2009, 02:49 AM
A20SVT00's Avatar
awsome build
Old 05-20-2009, 09:52 AM
Elliott's94Z's Avatar
Looking good man
Old 05-20-2009, 01:47 PM
Camaro-BMF's Avatar
What Cam did you end up going with?
Old 05-20-2009, 01:51 PM
baylove's Avatar
damn thats clean
Old 05-20-2009, 08:38 PM
BLINGOLE's Avatar
What no pictures of the lower end? I wanted to see how you clearanced everythng
Old 05-21-2009, 12:26 AM
Jose93z28's Avatar
It has a baby cam comp cams 07-305-8 114 lobe .510 .510 lift w 1.5 rocker
I called comp cams and they said it should be a good supercharger/turbo cam for street use.
Old 05-21-2009, 12:37 AM
Jose93z28's Avatar
Thanks guys and here's a few pics of the lower end everything was clearanced by the machine shop its not that bad to do I guess.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
My oil pump more than just tack welded
[IMG][/IMG]
Old 05-21-2009, 12:43 AM
Chevyguy358's Avatar
Very nice...Good luck with the rest of the install process
Old 05-22-2009, 07:55 PM
Jose93z28's Avatar
Thanks Ill be posting more pics as I go
Old 05-24-2009, 02:52 PM
Jose93z28's Avatar
Here's a pic of the engine back in its home, I also did the Ac delete panel from PCM4less, getting there slowly but surely.
[IMG][/IMG]
Old 05-24-2009, 02:56 PM
95RamAirNC's Avatar
awesome man, nice build
Old 05-25-2009, 04:56 AM
97Z28SS's Avatar
Are your crank and rods 4340 forged steel or is that a cast steel crank and how much boost are you running?
Old 05-25-2009, 05:07 AM
denice25's Avatar
nice build..looks very good mate!
Old 05-25-2009, 09:18 AM
SoxXpupPeT's Avatar
are you running self aligning rockers ??? what rpm is that engine going to be seeing ?
Old 05-25-2009, 02:12 PM
Jose93z28's Avatar
4340 and I should be seeing 8 street and hopefully if I can get it tunned right 12psi for track
Old 05-25-2009, 02:14 PM
Jose93z28's Avatar
They're self aligning rockers and Im thinking of about 6k rpms.
Quick Reply: A few pics of my 383 lt1 build
