Cam install finished
Old 05-20-2009, 09:37 AM
TRANSAM GT4's Avatar
Default Cam install finished
Well it's finally over and done with after an all nighter. I wanted to think this site and users for all the information shared. I really done alot of research and the TA runs better than I expected.
I went with a custom grind cam from comp, 1.6 crane 11746-16 rockers, crane 10308-1 valve springs, comp R lifters, 7608 push rods, gmpp guide plates, LT pacesetter headers, ory-pipe, 30lb injectors, and Trifecta tune.
Everything went really smooth. We pulled the motor out the bottom in about five hours, tore the motor down, put it back together the next day, and then spent all night getting it done. I did get a timing chain set for a 95 and up, so I had to wait on another one. If anyone wants to buy a cloyes 95 up timing gear and chain pm me. The headers caused a small fire on a dust cover, and they also baked off the heat paint but other than that everything went better than expected.
The crane 1.6 rockers work great and you don't have to trim the valve covers.
The car does seem very, very loud now. I hope that doesn't cause problems.
I do have one question for you guys running a cam close to the cc503.
Where did you guys set your idle? I have mine at 1000 rpm and it seems a bit high. It seems it idles too fast to give a good lope but I wondered if it were lower how it would act. Any thoughts?
I attached a few pics.
Attached Thumbnails Cam install finished-dsc00302.jpg   Cam install finished-dsc00299.jpg   Cam install finished-dsc00300.jpg
Old 05-20-2009, 09:48 AM
Elliott's94Z's Avatar
I had a LE grind similar to the CC503 and mine held idle at about 700-750. Have you got it tuned yet? Check the IAC (Idle Air Control), TPS (Throttle Position Sensor) if so...
Old 05-20-2009, 09:57 AM
Yeah, I tuned it already. I figured I would have to live with it and it's not that bad. Just doesn't lope like I wanted.
Old 05-20-2009, 09:59 AM
So is it the CC503 you are running or a custom grind? What are the specs if it's a custom. LSA??
Old 05-20-2009, 10:03 AM
GoFastKid's Avatar
+1 check the iac and tps same thing happened to me after my swap. Adjusted the tps and worked itself out. Mine sits around 650-700 at idle.
Old 05-20-2009, 11:02 AM
94Z28-MSTGKLR's Avatar
Cool! Now all you need to do is hit the track. Are you running an auto or a 6spd? If auto, definantly need gears to go with the cam if you haven't done them already. I just did a swap with the LT4 kit and with the 2.73 rear it still feels slow, lol.
Old 05-20-2009, 11:18 AM
LOL...Yeah you need some 3.73's bro! They will wake your car up big time
Old 05-20-2009, 12:43 PM
ss.slp.ls1's Avatar
I have a very similar build to you:
CC503
Crane 10308 springs
Comp 1.6 Pro Mags
TF guideplates
TF chromemoly pr's
PS LT headers & ORY
PP 52mm TB
Cobra 39# injectors
MadTuner tune.
My idle is set to 750, lope is nice. Call up Trifecta and see what your tune is set to. If it is not 1000, check your IAC and check for vacuum leak(s).
Old 05-20-2009, 01:18 PM
I set the idle to 1000 from Trifecta. I thought I read where that was a good idle set. I wasn't sure if I could change it afterwords. Can I def. change the idle with the tps & iac?
I am running a custom grind with the specs very close to the cc503. The cam card reads intake .502 Exhaust .510, Duration 275, 281, @.050 224, 230 and the LS is 114.
I installed a .373 gear several years back so I'm good there and it's a six speed car. I had a friend drive it that drag races alot, he said it would run low eights in the eight mile if It hook'd. I really don't care it's more of a street car, I have never took it to the strip. Who knows I may some day.
Old 05-20-2009, 02:04 PM
ss.slp.ls1's Avatar
You can't change the idle, you need to have it retuned.
Specs sound just like a CC503 with a wider LSA. What lobes were used? The CC503 uses Comp's XE lobes.
Old 05-20-2009, 05:45 PM
Thanks, that is what I suspected, it's not worth another tune, I can live with it. I'll look back at the cam card later, I'm at work now.
Old 05-20-2009, 07:40 PM
JAKEJR's Avatar
Could be that your throttle body butterflies are just open a little too far and not allowing the engine to idle down. I had to tweak mine on two of my L98 engines and on my 388 LT1 when I installed a 58mm BBK throttle body.
There's a minimum airflow adjustment screw on the driver's side of the throttle body which can be turned counter-clockwise to slightly close the butterflies, lowering the idle speed. This could allow the IAC to take over control of the idle speed and maintain whatever RPM was programmed in the PCM.
If the butterflies are open too wide, the IAC can zero out (fully close its pintel) and the rpms still won't drop to the programmed idle speed.
Using that little screw will also effect the TPS voltage reading, so the TPS voltage should be checked after making the adjustment. Golen Engines website shows their procedure for checking and adjusting the TPS voltage.
Of course, I'm assuming you don't have any other problem like a vacuum leak and that your IAC and TPS are working properly.
Hope this help.
West Point ROCKS!
Old 05-20-2009, 07:44 PM
ss.slp.ls1's Avatar
Hope this help.
West Point ROCKS!
He said he had is tune set to 1000rpm...
Old 05-20-2009, 10:24 PM
I don't have any vacuum leaks that I know of, We checked several times. I couldn't find anything on the card about XE lobes. It was ground a few years back. I wanted the 503 cam but a fella had this one fairly cheap so I bought it.
Old 05-21-2009, 11:03 AM
JAKEJR's Avatar
Oh, okay. I misunderstood what he meant by that (I had the idle set . . .) If that's what he had programmed in to the PCM, then he's stuck with the 1000 rpm idle speed until he has it reprogrammed.
Jake
West Point ROCKS!
Quick Reply: Cam install finished
